730D crank end threads buggered
mjbrown
06-23-2006 14:33:56
I need to adjust the crank end play on my 730D with a taper lock flywheel. The flywheel loosend up. I will have to get a new stake nut but the threads on the end of the crank are a little buggered up. Any one know where to get a die to chase these threads?
Mike M
06-23-2006 18:57:42
 Re: 730D crank end threads buggered in reply to mjbrown, 06-23-2006 14:33:56
The taper lock uses its own threads on the collet that slips over the crankshaft and it covers up the original crank threads. Maybe you have the collet (center piece of the flywheel) threads buggered. Try a small three sided file to clean them up.
mjbrown
06-24-2006 06:01:26
 Re: 730D crank end threads buggered in reply to Mike M, 06-23-2006 18:57:42
On mine the collet doesn't cover the crank threads but leaves about enough to put on a stake nut. Maybe I don't need the stake nut. I clearly need to check the big square nut on the collet once in a while though.
The thread file approach is my plan B.
msb
06-23-2006 22:04:10
Or you can buy a thread file.It is a good addition to anyone's toolbox.Usually have 8 different thread pitchs on them Makes a wonderful gift for the tinkerer.Not very expensive either.
