730D 3PT Sway control
CFWelles
06-23-2006 12:57:41
I just purchased an MX7 used for my 730D ES that I have been getting back to working condition. Have a few observations after using the cutter to mow about ten acres.
First I spaced the sway blocks out with the round spacers off the elephant ears and this set up the arms quite well to control the three point. There is just a little slop. But am concerned that this cutter may put too much pressure on the blocks and elephant ears. Cutter weighs 1300 lbs. Are the sway blocks and elephant ears desinged to take these loads?
Also, the three point seems to have its hands full lifting this unit for transport and I am thinking that I had better get used to running the short road distances using the tail wheel to carry some of the load. Anyone know if 1300 lbs. is pushing it for a 730 three point?
Tractor handles cutter and I just sharpened the blades to cut the hp load in higher grass. Tractor seems to handle just about any kind of hay as long as the up grades don't get too steep. Would say that this 7 foot cutter is all that the 730 should handle.
Would appreciate any comments any of you experienced farmers might have on the sway control and load lifting capability.
Glen in TX
06-23-2006 21:07:18
 Re: 730D 3PT Sway control in reply to CFWelles, 06-23-2006 12:57:41
Don't think I'd worry about it breaking the elephant ears as long as the bolts are tight and lift pins on arms are good. I'm talking about the pins that hold lift arms to tractor. Make sure they aren't worn with slack in them or wear in any other 3point pins. Maybe you need some weights up on front? Cousin use to run a 720 LP with a 8 row rotary hoe and it handled it fine.
CFWelles
06-24-2006 02:22:23
 Re: 730D 3PT Sway control in reply to Glen in TX, 06-23-2006 21:07:18
Thanks Glenn. You spend a lot of time giving your informed comments to questions here. Hope everyone appreciates it as much as I do. You mentioned front weights. She already pulled up a little on me going up a good rise. I wasn't worried about turning over because I had the cutter down and working, but your comment is right on. I have a three piece original set and they are going on the front. Needed here. Never would have thought of the mounting pins. Will look at them again, but think they are pretty good. Had the whole three point off just a short while back when I removed the rock shaft housing to put new seals in the input shaft to the pto pump when I rebuilt the powershaft assembly. Thanks again.
Glen in TX
06-24-2006 08:57:12
 Re: 730D 3PT Sway control in reply to CFWelles, 06-24-2006 02:22:23
I mentioned the pins just because had those wear a lot on new generation tractors and it never hurt to crawl under one and check pin clips and pin wear on them. Affects draft control and causes early wear on load control shafts on new gen. tractors. Just look at it as another preventative thing when hired hands do good to check oil and start and go and never check other things. Yours may be fine it you just checked them and a little different on a 730.
Mike M
06-23-2006 19:07:54
How much does a fully mounted 4 bottom plow weigh ? it should handle this all day. I have used a 3 pt. forks to lift a generator unit that weighs 1500 lbs. no problem.
CFWelles
06-24-2006 02:41:53
 Re: 730D 3PT Sway control in reply to Mike M, 06-23-2006 19:07:54
Thanks Mike. I had a real good reply written to your message and forgot to click after previewing it and lost it. Anyway, I appreciate your comment about what weight you have handled very much. Both your comment and Glenn's was the kind I was looking for. Anyway, your comment tells me that my three point is lifting fine. The three point ends up lifting by torque as everything is in a lever arm off the hydraulic ram inside. So my MX7 is a tough load because the weight center is so far back, maybe 5 feet behind the rockshafts. Said another way, it would be like lifting this cutter at the tips of your forks. I think it is fair to say based on your experience that my hydraulics are OK and this cutter is probably about it for this tractor. If someone could say that the three point is strong enough to lift the tractor front up without any front weights, that would be good information. This cutter when lifted makes my front quite lite, but actually doesn't pick it. Thanks again for your lifting comment.
Mike M
06-24-2006 05:31:19
 Re: 730D 3PT Sway control in reply to CFWelles, 06-24-2006 02:41:53
I have benn battleing power outages.
Those who do use mounted plows DO have the weights on the front end.
