How Do I shut this thing off!!!
Tom Colbath
06-23-2006 09:10:53
I recently Bought a 1950 B Serial # 259608 There dosent appear to be a switch to turn the tractor on and off, what is the recomended way to do this.
Any info you have would be most helpful thanks.
Bus Driver
06-25-2006 09:55:58
 Re: How Do I shut this thing off!!! in reply to Tom Colbath, 06-23-2006 09:10:53
The 1939 G had no kill switch. We ran it on kerosene except for cranking. To stop, we shut off the fuel and kept the throttle almost fully open. It would really run the carburetor dry. It was then ready for the gasoline for the next start. It rarely would crank on kerosene, only if hot and we could roll it down a hill.
rob nickel
06-25-2006 06:20:04
My 41 A has a Wico C mag and no kill switch. I generally just idle her down and then shut off the gas at the bowl. She'll run on for a bit and will not die just from having the throttle all the way towards the slow side. It's alway's kind of fun anyway to see just how slow these old girl's will run? And I alway's get a kick out of it when your sure that she's popped her last but then one plug fire's and away she go's all over again until the fuel eventually runs out.
Tom Colbath
06-24-2006 06:51:18
Thank You all for the reply"s
Brendon
06-23-2006 19:01:59
My '50 magneto ignition model B simply shuts down when I pull the throttle lever all the way back. This is also what the manual instructs you to do with the mag ignition, gasoline models. With the battery ignition models there is a key switch that shuts it off. All-fuel versions must have the carb drained either manually or by shutting off the supply and letting it run until it dies.
johns48b
06-23-2006 14:15:06
i liked the comment by sams#3 about gas not being cheap back then either. i don't remember where i read this or was told this at a tractor show but it seems like an eldery farmer didn't like the idea of cutting off the gas and letting the tractor die on its own. he thought it was wasting gas to do it this way, so he kept a snuff can in the tool box and after shuting the fuel off he would open the drain on the bottom of the carb and catch the gas in the snuff can and pour it back into the tank. i keep one in the tool box on my b that i show and occasionaly somebody will ask me about it and i'll tell him this story. i've also heard that you should engage the clutch after you take it out of gear and cut the gas off. any thoughts about engaging the clutch or not?
Sam#3
06-23-2006 17:58:01
 Re: How Do I shut this thing off!!! in reply to johns48b, 06-23-2006 14:15:06
The manual for Dad's H said, and I paraphrase, "it was best to engage the clutch when parking with the engine running." Something about allowing the engine and transmission to turn as one unit. My own thought was/is it would save any wear on the clutch facing.
And yes the same manual had a picture of draining the carburetor but that was more of a distillate fuel item. We ran gas or a gas/kerosene mix so starting wasn't a problem.
Sam#3
06-23-2006 13:11:58
There are as many ways to kill them as there are to start them. Before electric starters you sought the best of both.
If you have an all-fuel with the fuel valve control on the dash you can, with a little practice, learn when to shut off the fuel valve before you get to your destination. A few revs and it dies.
Yeah, Gas didn't come from from the creek in the fifties either.
jd40an
06-23-2006 12:35:19
Though shutting the fuel off & letting it run dry is probably the best way to stop a mag equipped tractor that doesn't have a grounding switch, I grew up on "A"s & "B"s and we always just idled them as slow as possible & killed them by putting in gear, holding the brakes,& engaging the clutch. I could never see that this harmed the tractor in any way. It also was quick & easy.
Glen in TX
06-23-2006 09:50:51
In the JD manuals they recommended shutting the fuel off and letting it run out to kill them. Battery ignitions of course just have a switch to cut power off. With magneto ignition you need a kill terminal on it present to hook to a grounding switch or grounding source. Some have a little grounding strap with insulated button on it. NEVER hook a magneto to a battery voltage source or you will fry the mag! A magneto produces it's own power. There are SPECIAL starting key switches made with a magneto kill on them but NEVER hook the mag terminal up on a regular battery ignition switch or you chance ruining the mag. I and others have kits available to add to your mag if you want a kill terminal on it. They aren't hard to install and I even provide instructions with my kits. Email me if you want to see Wico instructions for a kill kit. Many like to have a quick kill terminal available for safety.
machinery-man
06-23-2006 09:40:20
the tractor came from factory with throttle shut off position. In other works pulling back on the throttle control completely closed the butterfly. This was a safety feature and would prevent the governor from taking control from an idle situation. However lazy individuals figured this was not proper and bent the throttle stop forward and thus prevented the shut down. Of course when the tractor got in an awarkward or unsafe position the governor would still kick open and I am confident many accidents occured as the operator couldn"t then just grab the throttle for the shut down. Obviously he could reach forward and pull the optional kill switch. This shut down also allowed a clean non wash shutdown. If you check the original owners manual you will see this.
P Browning
06-23-2006 09:33:49
Do your tractor a big favor -- Buy the Manuals you desparately need. Call 1-800-522-7448 with your credit card in hand! (PatB)
John T
06-23-2006 09:25:12
Tom, I like to shut mine off by turning off the gas like at the sediment bowl shut off (if so equipped) and let her die. Thats good to do when setting anyway in case the float and/or needle n seat fails which can gas flood the carb n engine. I take it its a Magneto Ignition, and some like the Wico X had a Kill Switch mounted on their sides which killed the spark when depressed. Others that had the kill switch stud option ran a wire up to the dash where they had a kill switch (or even an On/Off or a key) that simply grounded out that kill stud same as when the side mag button equipped units were depressed.
DO NOT KILL IT BY CHOKING that lets raw gas wash all the oil from the cylinder walls n rings
If it dont have the kill switch option on the Mag and you dont wanna use the shut the gas off method, you could idle it down real slow n in high gear engage the clutch with the brakes appled n kill the engine but I DONT LIKE TO DO THAT EITHER
The other way is to manually (or if throttle allows) hold the carb as far off as it will go n she can die. It depends on the carb and its settings and the idle stop screw adjustment and the lil stop spring etc as to whether it will die when the throttle or carb butterfly is pulled all the way off to shut down, TRY IT N SEE Many will die if the throtle or carb butterfly is manually pulled to the slow or shutdown position.
If it dont have a Mag with a kill switch, I recommend the shut the gas off method myslef (actually even if it has the kill switch I prefer it)
John T
