How wide do I go? JD 4010
TimS
06-23-2006 08:32:49
How wide do you folks set your front and rear wheels for brush hogging, hay mowing/raking/baling? The property we have has some pretty good hills on it ( NW Missouri ).
I thought about just setting to the max width since I don't have any row crops to worry about getting the spacing right for.
j cook (iowa)
06-23-2006 09:22:47
 Re: How wide do I go? JD 4010 in reply to TimS, 06-23-2006 08:32:49
You set your wheels, providing you can actually move them at all, so that they do not roll over the crop.
For cutting hay, that means that both front and rear wheels are spaced so that they pass along the space between swaths. If you use a 9' moco, that works out to be 84-88" between the inside edges of the tires. (Some people use their moco to windrow when cutting, making wheel spacing a little less important. My suggestion of 84"-88" is for when laying a hay swath FLAT, for faster curing time.)
For brush cutting, you wnat the wheel tracks to be entirely within the "cut" of the brush cutter. If it is a 7' cutter that means that the wheels have to fit INSIDE the maximum 84" width of cut.
For row crops, you would most likely want your tires to be able to roll along the space between rows, so it all depends on what spacing you are using.
Your owners manual for your plow (assuming you use one) tells you what spacing to use for that.
