HOW TO GET ROLLOMATIC APART
zach15
06-23-2006 06:54:31
I have a 1951 jd b with a rollomatic front end. I have the housing off the tractor (very heavy)but i cannot get the shaft out. I took the nut of the top and hit with a block of wood and a hammer for about an hour but it wont budge. Am i missing something or what have other people done to get it out. Any help would be great Thanks
Mike M
06-23-2006 19:05:03
 Re: HOW TO GET ROLLOMATIC APART in reply to zach15, 06-23-2006 06:54:31
If you are trying to get the vertical shaft out of the pedestal at the top where the steering worn is then support the front frame so the front wheels are off the ground then since you have the nut off get a harder piece of wood and try whacking it with a bigger hammer. You may need to put a nut back on to protect the threads and use a piece of brass or aluminum and if all else fails steel it should pop the gear free from the taper on the shaft.
Kurt_JDB
06-23-2006 09:43:47
If what you are asking about is removing the vertical steering shaft from the rollomatic housing, this shaft is rivited to the housing with either one or two rivets. It will necessary to drill out these rivets, and probably use a hydraulic press and some heat to get it apart.
If what you are talking about is the spindle/gear assembly, remove the cover from each side of the housing, remove the lock wire and two bolts. It should come right apart.
Kurt
