1530 water in oil
Ricky Dean
06-22-2006 13:50:49
Help. I have a john deere 1530 sometimes it gets a little water in the oil.What happens it will sit a day or so you check the water it will be about 1/3 of a gallon low. it will be in the crank case. sometimes it will be weeks before this happens again.Replaced the head gasket and checked the head for cracks no crarks were in the head.never had to add water when I am running the tractor.
Roy Suomi
06-22-2006 19:53:20
 Re: 1530 water in oil in reply to Ricky Dean, 06-22-2006 13:50:49
Age old liner problem...Hole eroded in the cylinder liner wall... drop the oil pan , place a couple of coffee cans underneth directly below the cylinders..Check the cans in the morning to see which liner is leaking..Liners simply push from the bottom up with a bar and a bottle jack..Note; be sure to wear a rain hat when you push up the liners with a solid bar and a bottle jack..It'll rain on you...Replace all the liners. Don't be cheap and have to do this again a month from now...The erosion is caused by poor antifreeze hygene and hard water..Use NAPA's coolant conditioner as per instructions after rebuild..In extreme cases , the block will have erosion where the o-rings seal the liners..I've used liquid steel on non-warranty jobs...
