1934 john deere B
tseaberg
06-21-2006 20:08:34
I have a friend that is selling a john deere B and is serial number 1755. I heard that they made a few B"s in 34" and I was wondering how many b"s john deere built in 34". and if serial number 1755 would be a 34" or 35".
thanks tom.
jd40an
06-22-2006 13:33:38
 Re: 1934 john deere B in reply to tseaberg, 06-21-2006 20:08:34
As far as I know the earliest "B"s were considered '35 models, However my production register shows #1947 to be the last built & shipped on 12/31/34. Your friends tractor #1755 was built & shipped on 12/24/34 to Minneapolis branch,final desitnation of Kennedy MN.
j cook (iowa)
06-22-2006 11:46:16
According to the production logs, as published in the Spring 1994 edition of TRACTOR DIGEST there were:
September 1934 3 "B"
October 1934 68 "B" 11 "BN"
November 1934 381 "B"
December 1934 532 "B" 10 "BN"
by my count, the serial number would have reached sn: B2004 by December 31, 1934/ Of course all of these tractors are 1935 models, there ARE no 1934 model year "B" tractors/
Kevin Black
06-22-2006 10:46:17
The first unstyled B's were manufactured with a 4-Bolt Pedistal. This proved to be a weak point and Deere re-engineered the front pedistal adding an additional 4 Bolts (Totaling 8) for strength. The last "4-Bolt B" produced carried serial # 3042 so the tractor you are looking at should have the 4-Bolt front pedistal unless it broke and someone re-placed it. This tractor would be worth a good bit more that the 8-Bolt B's. Refer to P Browinings post in ref. to the year model because he hit the nail on the head when talking about the year model designation.
Glen in TX
06-22-2006 08:21:09
B # 1000 does show to be the start of 1935 models. Get a serial number research done for it with Two Cylinder Club and then you should know when it was made at the factory and if they have the info where it was delivered also. You won't always get the delivery info or maybe just a branch location. Info is at their site on RH side column.
John T
06-22-2006 06:40:24
Tom and others, werent the first 2000 Model B's made the 4 bolt mounted front pedestal versus the later 8 bolt also???? which makes them more rare and collectible????? ??
John T
P Browning
06-22-2006 06:28:52
1935 was the first production year for model B tractors. What you have to understand is that a production year and a calendar year are not the same periods of time -- just as the fiscal year for the Federal Government. 1935 JD-B production most likely began in August of 1934, and they may in fact have been at dealerships before the year 1934 came to a close. What is important about a JD serial number is its significance when procuring replacement parts, not the day & hour is passed final quality control inspection and was shipped! (PatB)
85_Ranger4x4
06-21-2006 20:41:27
It might have been sold in 1935 as a 1936 model. Like how you can get 2007 cars right now in 2006.
Earl-IL
06-21-2006 20:25:33
My sheets says 1935 was first year. "B" serial #'s start at 1000 . Earl
