40 stabilizer bars
fredmich
06-21-2006 18:56:00
My son just became the new owner of a nice JD40S and wants to use his 5ft finish mower on it. He needs some type of stabilizer bars to keep it from moving from side to side. Did JD offer the bars or can someone recommend where to get some or offer a solution. Thanks....Fred
lowlander
06-23-2006 18:39:26
 Re: 40 stabilizer bars in reply to fredmich, 06-21-2006 18:56:00
Fredmich : I have one of the stabilizers that Fred describes that came with a 40T that we had. Forty dollars will buy it. I am in sw michigan
Hayfarmer
06-22-2006 12:35:31
I had a similar problem on my 430U. My uncle purchased, from Deere a device that worked as a stabelizer. The center part of the U goes over the dreawbar on the tractor and the arms extend out to the lower hitch pins on the 3 point hook up. The arms are adjustable. The thing is rather heavy and seems better at pinching fingers than holding things. I made up stabelizer brs similar to the Ford style. I am not sure what the drawbar support looks like on your 40, on the 430 I went to the inside of the support, just in from there the 3 point arms hook, and installed short pins. I made up one side bar that is stiff while the other side is a adjustable, like a skinny top link but longer, I believe it is made by Speeco or similar. You need to find some point so the arms and stabelizer bars are as close to the same height wise so they do not bind up at one end or the other. I am not familiar with the "wishbone" setup mentioned here.
Jim in NC
06-22-2006 02:57:03
Your lift arms will have chains attached to them. The wishbone shaped bar is the stabilizer. It is attached with one long pin to the rear of the tractor above the pto shaft ane the other end fits jusr below the top link on your implement betweem the two pieces that are bolted together to form the top hitching point. It just lays on top of the bolt and spacer that holds your implement hitch together. I use it on all of the 3 point implements that I use on the 40. I do not have any special implements for just the 40.
Fred MIlls
06-21-2006 20:08:58
The JD 40 does not have stabilizer bars like a Ford 8n for example.It uses a bracket on the rear housing that you can have in the up or down position. Looks like a plate with a slot in the middle. Not effective.
There is a centering yoke used on the rear cultivator. A tunnining fork like device fits into a slot on the equipment. The fork attaches to the tractor rear just under the rocker arms. Your bush hog would require the slot to work. I might have a picture in my 40 manual.
