I guess I would like to see a test performed while running to see if the problem is spark or gas. I have an old neon timing light that is self-powered and whenever I have a situation of an engine cutting out under load, I tape that thing to the hood with a piece of cardboard for a sunshade and hook it up. If the light stops flashing as the engine dies, I know I need to look for an ignition problem (BTW, those engines use a potted ignition module I believe, and those are great candidates for skipping when affected by heat). If the spark stops, move it to the garage and cool it down while you go to the bathroom and get the wife's blow dryer. Heat that module up as the engine is running with no load and if it quits as you heat the module, you've found the problem. If it sparks right down to the last turn and in fact still sparks as it cranks over but does not fire, it's got to be fuel delivery. Check the fuel delivery by cranking the engine and observe good flow and in the appropriate amount. Next look for a kinked fuel line, the proper vented/unvented cap (not sure which yours uses), and cean the screen in the bottom of the tank. If it sparks right and fuels right, check that the timing is right on. If it's off to one side of the mark, the engine might not be able to carry through those boughts with heat. Deere must have sold thousands of those units and many other manufacturers have used that engine, so maybe check for a field service bulletin on that issue. OR....call a dealer in the south where it gets hot like in Florida or Texas and ask what they have experienced. Other than that, I have no idea what to do. Frank
