Dual Cylinder/Single Rockshaft
Osage
06-21-2006 13:56:00
Well I'm waiting on my new rockshaft seals and housing gasket to arrive; I'm always trying to learn a little more about my John Deere 1965 1010RU.
Question: What was the design purpose of dual hydraulic cylinders (both of which function in unison) connected to a single solid rock shaft utilizing only one control lever?
At first I thought one might be for down pressure, however as stated both pistons push in the same direction and there is a gravity assisted down pressure spring on the right lift arm.
Any wisdom would be appreciated
Thanks,
Osage
Bob
06-22-2006 06:23:39
 Re: Dual Cylinder/Single Rockshaft in reply to Osage, 06-21-2006 13:56:00
I'm woking on a 2010, with a similar system. My GUESS is that using the 2 cylinders with the single rockshaft simply gives the same lifting capacity to the single shaft as the total lift capacity of the split system... each cylinder's piston has "X" number of square inches of face area, multiplied times the hydraulic pressure, giving the pounds of force applied to the lever on the rockshaft.
The 2 cylinders together simply provid twice the force one alone would, at a given system pressure.
buickanddeere
06-22-2006 17:34:18
 Re: Dual Cylinder/Single Rockshaft in reply to Bob, 06-22-2006 06:23:39
Dual rockshaft pinned together will lift about double the single will on a 40/420/430/320/330/435/440/1010.
Osage
06-22-2006 10:31:25
Bob:
Your logic is exactly what I originally thought, however I've not found any reference to a single shaft/single cylinder system being a weak design.
I talked to my local dealer and he doesn't have a clue either, however he wasn't even born yet in 1965.
Thanks,
Osage
Tx Jim
06-22-2006 03:52:30
If it has a split rockshaft then each side of front cultivators raised independently for point rows. Tx Jim
Osage
06-22-2006 05:49:00
 Re: Dual Cylinder/Single Rockshaft in reply to Tx Jim, 06-22-2006 03:52:30
Jim:
As stated mine is a single solid rockshaft, dual cylinder with one control lever .
Apparently there were three different designs;(1)single rockshaft single cylinder one control lever,(2)single rockshaft dual cylinder one control lever,(3)split rockshaft dual cylinder two control levers.
Thanks,
Osage
