4010 Hydraulics- Problem/Question
JKR4010
06-21-2006 05:03:57
Hello. I purchased a JD 4010 last winter and have recently noticed the hydraulics seem to be acting strange. When I first start the tractor after it sits for a day, I have no steering or 3PT movement for approximately 15 seconds. After 15 seconds, it sounds like the pump finally kicks in because engine RPMs will drop slightly and I can feel a light load on the engine. When this happens, power steering returns and the 3PT slowly lifts (chattering all the way). When warm, the steering works fine but the 3PT continues to chatter while lifting. I changed the hydraulic filter and removed the hydraulic screen (which was clean) to no avail. The fluid level is full on the dipstick.
Has anyone experienced a problem as described above? I am afraid the hydraulic pump is failing; any idea of cost to fix?
Thank you in advance for any help!
Gerald J.
06-21-2006 09:28:04
 Re: 4010 Hydraulics- Problem/Question in reply to JKR4010, 06-21-2006 05:03:57
You probably need to replace the check valve in the transmission. That's a lot of work so there's a JD service information bulletin on convering an elbow to that check valve. When I did it for my 4020, it cost about $10.50 for parts. Look at http://www.geraldj.networkiowa.com/4020si.htm for more information on the update.
Gerald J.
zwr
06-21-2006 18:36:15
 Re: 4010 Hydraulics- Problem/Question in reply to Gerald J., 06-21-2006 09:28:04
Thanks for the info. Do you know whether this fix will work for 4020's after 201000?
Gerald J.
06-21-2006 19:22:29
 Re: 4010 Hydraulics- Problem/Question in reply to zwr, 06-21-2006 18:36:15
I know it will not work for side console tractors. I think I listed the models and serial numbers on my web page.
There is a different problem in the later 4020 that is covered in service bulletins, but since I don't have the later tractor, I don't have it memorized. A good JD shop foreman should be able to find it. I have seen it in my collection of service bulletins but it could take hours to find it. Probably '69 to 72 vintage.
I learned this service information from a JD shop foreman who had it on microfiche but had no printer for them so I made the rough scratched notes. I know others have found the modern computer version by that service information number but it didn't come with illustrations.
Gerald J.
JKR4010
06-21-2006 16:53:42
Thank you very much for the informative information- I will try this as soon as I get a chance to work on the tractor. Again, appreciate the help.
Mike M
06-21-2006 05:33:41
Make sure you start with the clutch out so the tranny pump can turn right away. Other than that I'd say all those tractor do this to some extreme. If your 3 pt. drops when shut off it may have a leak in the thermal relief I think that's what it is called and our 4020 needed this reseated and it now stays up.
