Transmission Problem
Angelo Indiana
06-20-2006 23:29:14
I am looking at buying a 52 John Deer A. The engine is good in it, but there were some transmission problems in it. The owner showed me some of the parts. He said it needs some new bearings and that the sliding gear and the counter shaft on the tractor needed to be replaced. How hard is it to replace these parts, and how costly are these parts? The owner also said that that the PTO was working on the tractor before he took it apart. Is it worth buying the tractor myself and fixing it?
Angelo Indiana
06-21-2006 06:42:41
 Re: Transmission Problem in reply to Angelo Indiana, 06-20-2006 23:29:14
Mike he is asking $500.Is that too much? plus it has a 3 point hitch. Thanks angelo
P Browning
06-21-2006 07:18:34
 Re: Transmission Problem in reply to Angelo Indiana, 06-21-2006 06:42:41
Angelo -- I have seen a complete 3-point hitch for that tractor sell for nearly $500! And the after-market jobs run higher.
If nothing else, perhaps it would make a very wise investment as a parts tractor for an A of similar vintage! (PatB)
Mike M
06-21-2006 07:16:15
If it has the John Deere made 800 series hitch then it alone is worth that much.
If you are looking for a project to keep you out of trouble than I'd go for it. Even most of the ones that are still running around need work on them too.
Angelo Indiana
06-21-2006 11:00:24
 Re: Transmission Problem in reply to Mike M, 06-21-2006 07:16:15
Mike how do you know if the 3 point hitch is original or after market. I am new to this tractor thing.Will it have any kind of no. stamped on it? Thanks Angelo
Mike M
06-21-2006 11:31:04
 Re: Transmission Problem in reply to Angelo Indiana, 06-21-2006 11:00:24
Hurry up and check out photo ad # 139692 this is an original style hitch so if it looks anything like this it is worth $500 as you can see as this one is sold !
Mike M
06-21-2006 04:42:40
How much is he asking for it ?
