Antique Tractor Rules
WNYGSEA in New
06-20-2006 19:26:00
Is anybody going to the WNYG&SEA rally Labor day weekend? I undersdtand that the antique pulling that takes place on Thursday Night is restricted to tractors that are 1939 or older. I have a 1942 Farmall M and have pulled this tractor at this event for the last 3 years at this event. So the rules change and I am out!! But the good news is I can pull on Saturday during the event with those annoying freckin garden tractors!! This totally sucks. I am a lifetime member and I think this is a cheap deal at best. Call Roy Metz at (585) 535-7878 and let him know that this decision to limit the age of the tractor to 1939 or older is a mistake!! Last year it was 1945 or older (60 years old).
buckeye al
06-21-2006 16:45:16
 Re: Antique Tractor Rules in reply to WNYGSEA in New Yorkd, 06-20-2006 19:26:00
This is a bit long but it's an interesting situation you pose.
See what the group thinks of dividing into more classes & maybe about the same number of pullers. Our group classes them '39 and older as Antiques with '40 through '55 as classics, 1, 2, and 3 plow with an option for 4 and up if a big boy shows up!
Occasionally we'll have a '39 H in our 2 plow Antique class. Same with an M in the 3 plow class. Some will grumble about them being there. Complaints like "I know he's got a power kit in there" and he has way too much HP. He shouldn't be in this class. What were those guys thinking? Well they're likely right and we all know it! Point is, there's more to a tractor pull than just HP. In reality, the H rarely beats all the F-20's. The F-20 with good traction is slow and it's a luggin brute by comparison so if his traction holds out and he doesn't misfire, he will probably out distance the H and then what's left to argue!
I know you have a '42 M but my point is, unless your pull is just plain too big and they're trying to reduce its size as others suggest, it might do well to establish a few more classes. If it's just too big, might it be better to put a cap of 30 (or whatever) tractors per class to fit the time available to run the pull and still have the more classes available?
Those that put on and conduct the pull have to keep the crowd! If the pull drags on too long, the crowd leaves and then what's the point? More classes CAN allow a better grouping of the tractors. A '42 M is a good bit different from a '37 F-30. Afterall, that's why they invented the M! Age isn't everything and we sometimes get so involved in the competition we loose track of the fact the pull is as much (if not more) for the crowd than the pullers! More classes allows less time to be spent on each class. There are more winners and more announcements. More action and more variety. It helps keep the crowd in the stands.
I admit, this may be a bit easier for me to say than may be possible in your group especially if there are prize monies involved at your pull. For us, there is no purse and no fee required to hook. We offer a 1st and 2nd place trophy with a 3rd place plaque. We bill the pull as a fun pull for the enjoyment of the crowd and pullers alike! We usually pull around a hundred tractors. There are more rules but this gives you an idea. No set of rules fits all the variables perfectly. There will always be some holes or sore spots unless you make only H's pull against H's and Green A's against Green A's. Where's the fun in that?
Both life's experiences and where I work have taught me it's better to offer a doable solution than to innundate the "rules guy" in this case Roy, with ten bushel of complaints! Find out (for sure and certain, not just what the rumor is) about the WHY behind the rule change and then it may make sense. It may also lead nicely into an even better sugestion! Maybe not but it is worth a try! Right now, what have you to loose? You can't pull as is unless you throw your integrity out the window & lie about you tractor's age and from the fact that you're concerned about the matter that you're not about to do that!
I guess that's a lot more than just 2 cents worth so I'll call it a nickle & wish you well Sir.
Later.
Mike M
06-21-2006 12:35:07
Well I can tell you how to beat them !!!!!
Since Farmall M's were first built in 1939, were they not ? All you have to do is get rid of the serial number tag !! and then tell them it's a 1939.
Drew
06-21-2006 13:30:09
 Re: Antique Tractor Rules in reply to Mike M, 06-21-2006 12:35:07
Im not a red expert, but I think there are several parts that are unique to the 1939 M that they may catch on to.
DSK
06-20-2006 20:05:50
I've been pulling antiques for 22 years and I have seen every trick in the book when it comes to overnight rule changes. Most of the time the "new" rule or rules are developed to keep out a certain tractor that some member of the self appointed executive rules committee has trouble with. If you belong to a club which is sponsering the pull, then the year break thing should have been discussed at one of your meetings and voted on by the members present. Maybe the club wants to limit the # of hooks on a certain day, but it should have been discussed first.
Whining complaining
06-20-2006 19:39:09
It takes a lot of work to put on a show and or tractor pull. Why don't you participate in the club more so you can get in on making the rules yourself instead of just complaining. The rule changes one little bunch wants to make can tear your club apart too. When rules change it needs to be voted on by the majority of the club unless you got lots of dead beat members that don't show for meetings during off season and then what you got now is what happens with rule changes. Sometimes the pulls get too big to handle for a small bunch and more help is needed to run it and some changes now and then are nice to have but it needs to be a club majority decision and not that of just a so called few "in charge".
06-20-2006 19:50:59
 Re: Antique Tractor Rules in reply to Whining complaining , 06-20-2006 19:39:09
Say what you want about "Whining complaining" but this club has over 1300 members. I should be at the meetings more but I travel almost full time at my regular job and weekends are precious for me and my family. As I said I have a Famrall M and the first year they were made was 1939..... ..
Whining complaining
06-20-2006 19:55:00
 Re: Antique Tractor Rules in reply to WNYGSEA in New Yorkd, 06-20-2006 19:50:59
Thought this was the John Deere forum and not the Famrall (Farmall) board??
Johns Antique 1940 Deere
06-20-2006 20:01:14
 Re: Antique Tractor Rules in reply to Whining complaining, 06-20-2006 19:55:00
Hey man....that guys got a point and uou are missing the ppoint. It is not about the tractor...it is about the antique tractor rules. The same goes for us green colored guys.
Whining complaining
06-20-2006 21:48:51
 Re: Antique Tractor Rules in reply to Johns Antique 1940 Deere, 06-20-2006 20:01:14
You did NOT even read my points in my first post. I've been singled out by quickie rule changes too and disqualified 2nd day of a pull because I beat out the club president first night of pull and that kind of BS just isn't right. People running pulls and clubs like that should not be allowed to run things because they just run off more that just want to have fun. So... it's just back to whining and complaining till you do something about it... Just go to another club or pull till things change.
