JD H rod specs
AC
06-20-2006 19:20:09
what is the center to center, journal diameter, and pin diameter on an H rod...thanks, AC
Glen in TX
06-21-2006 12:20:55
 Re: JD H rod specs in reply to AC, 06-20-2006 19:20:09
Per I&T JD-4 shop manual: JD H
Crankshaft journal diameter = 2.0615
Crankpin diameter = 2.0615
Piston pin diameter = 1.1045
Valve stem diameter = 0.372
Main bearing run clearance 2-4 thousandths
Rod Brg. Dia. clearance 1-3 "
Piston skirt clearance 3-6 "
Crankshaft end play 5-10 "
Much more H info at this link:
