3010 pump problems
oliverpullerguy
06-20-2006 19:05:32
Hi all i was wondering i have a 3010 deisel, and on the injector pump by the trhrottle linkage the is fuel running out.
can any one help me on this?
Glen in TX
06-22-2006 08:55:13
 Re: 3010 pump problems in reply to oliverpullerguy, 06-20-2006 19:05:32
There is a cover to remove to install a timing pin or use a engine turning tool to get in proper timing position before or after pump has been removed and usually no need to remove valve covers then. JD service manuals and I&T shop manuals show how to do that. The timing pin should be right there bolted on the tractor. It usually helps starting to retime it anyway when it's been off.
msb
06-20-2006 20:54:57
Its a common and simple repair.The throttle shaft o-ring needs replaced.It can be done without even removing the pump in most cases.
4010 Pride
06-20-2006 19:45:17
Well, it could be a couple of things. There could be an internal seal cracked or split. Or, there could be a split or a crack in the interior of the pump. Also could be exterior, clean it well and look at for cracks with a magnifying glass. All I can say is when I had my pump on my 4010 (roosamaster) rebuilt last summer, I reconnected the lines back up and 3 of them leaked for about a week. I had to keep going back and tightening them just a little more every day or so for a week as I ran the tractor. The rebuild costed me 475.00 and I was told that I got quite a deal. So, moral of the story is, the tractor ran like shit...skipping and smoking white until I stopped the leaking between the pump and the injector lines. You may have to remove your pump and get it looked at if there is no visible cracks or breaks in the housing. If you need to have it taken apart to have it looked at, you may want to think about taking it off and shipping it to a diesel shop for a rebuild or closer inspection. Get a quote first of course...for worst and best case scenario. Hope this helps!
Jon, Upstate New York
oliverpullerguy
06-21-2006 17:07:51
 Re: 3010 pump problems in reply to 4010 Pride, 06-20-2006 19:45:17
ok thanks for all the help guys.
4010 Pride
06-21-2006 18:44:02
 Re: 3010 pump problems in reply to oliverpullerguy, 06-21-2006 17:07:51
One more thing...if you do end up pulling the pump off to have it looked at or etc., make sure you put a "slash" or peen mark going from the engine block (where the pump mounts) to the very bottom of the pump. This will allow you to install the injection pump at the exact location that you removed it. Also, mark the shaft which is attached to the pump to make sure it is reinstalled exactly how you removed it. Otherwise you will mess up the timing and you may have to pull the valve covers to determine what stroke the engine is on. Good luck!
