More questions from the new deere owner
Kevin
06-20-2006 13:36:57
Well if you guys remember i bought a 60 a while back and im still learning. I was wondering whats with the dented muffler? Mine has a straght pipe that was made on a dyno and they got the most horsepower out of it when we used a ball peen hammer to put a dent in it just like the muffler.
Next question is were should the wire from the battery to the starter run? Mine was straight from the battery box to under the flywheel cover and it kinda just bout cut right in half and shorted out.
Jim Benson
06-21-2006 06:47:54
 Re: More questions from the new deere owner in reply to Kevin, 06-20-2006 13:36:57
The wire should pass under the floor pan and enter the flywheel cover at its top right corner if I remember correctly. Maybe somebody truncated the thing and just pulled up the slack.
Charles McNelly III
06-20-2006 16:40:49
The only thing that comes to mind Kevin with the dent thing would be it creates a venturi affect. I bet if you were take your tractor back to the dyno and built a step pipe, meaning start off with a smaller then factory size pipe coming off of the manifold and then go up you would get more torque for pulling. It worked for my Harley. Good Luck and have fun!
Charles
Stan - Florida
06-20-2006 14:06:20
Can't help on the wiring problem, and don't really know why a dent in the muffler would raise the power.
A 60 muffler would not have a dent in the side...those dented mufflers were used on the styled A tractors to allow for the steering rod to pass by them through the hood.
Stan
