JD-H VALVE SPRING SPECS
BLB
12-02-1999 10:19:14
DOES ANYONE KNOW THE SPECS OF THE VALVE SPRINGS ON A JD-H (1942) WAS GOING TO JUST REPLACE THEM BUT @ 15.00 EA I THINK I'LL SEE IF THEY REALY NEED REPLACEMENT OR IF ANYBODY HAS AN NON-OEM SOURCE....THANKS MUCH
Mike Aylward
12-03-1999 16:52:54
 Re: JD-H VALVE SPRING SPECS in reply to BLB, 12-02-1999 10:19:14
According to my information, the spec's on the springs are as follows: Compress to 2 5/8", 62-68 lbs. Hope this helps. Mike
mark
12-02-1999 17:56:30
instead of replacing your valve springs just find a washer to put under the spring. this tightens up the spring and keeps it from sucking open when not needed will also help it idle better i do this to all my valve jobs and really makes a difference.
BLB
12-03-1999 06:43:05
 Re: Re: JD-H VALVE SPRING SPECS in reply to mark, 12-02-1999 17:56:30
SOUNDS LIKE A GOOD IDEA TO ME!! HAS ANYBODY ELSE TRYED THIS BEFORE?
Tom Stinson
12-03-1999 09:04:05
 Re: Re: Re: JD-H VALVE SPRING SPECS in reply to BLB, 12-03-1999 06:43:05
Numerous times. The shims come in a couple different thickness that you can identify by the color. Copper .030, silver .015, and so on. Try to judge the total amount removed when you cut the seats and the valves combined to determine the thickness, and use a retainer to get the proper id and od. The only time we replace springs is in the event of a severely overheated engine, or one that is really old and high time. Tom S.
