JD 435 Wiring Diagram
Alkay
06-20-2006 09:51:18
Does anyone have a good wiring diagram of the 435? Especially for the gauges and behind the dash. We owned this tractor from 1964 to 1987 when it was sold with some property in Michigan. I bought the tractor back last year, but they had someone rewire it and now the gauges are all messed up. The hourmeter now works off the ignition only, not controlled by the pressure switch. Water temp is erratic, but I hooked a mechanical gauge up to check and the actual temp is fine. I have the original JD operator's manual and the two IT manuals, but they don't show a very good diagram at all. Please help!
Glen in TX
06-20-2006 13:07:28
 Re: JD 435 Wiring Diagram in reply to Alkay, 06-20-2006 09:51:18
This is found by using the search box at top of forum....
Link
alkay
06-20-2006 13:16:45
 Re: JD 435 Wiring Diagram in reply to Glen in TX, 06-20-2006 13:07:28
Glen, It looks like this thread brings up the same points, that there is not a good wiring diagram for the 435 in the manuals. Do you know if any of these manuals has a decent diagram? All of the manuals I have looked through are very basic, not like an automotive manual that has the detail I need. Thanks
Glen in TX
06-20-2006 13:30:36
 Re: JD 435 Wiring Diagram in reply to alkay, 06-20-2006 13:16:45
The 440 wiring diagram is shown well in the SM2029 electrical manual but it is with a 4 terminal regulator. I'm not sure what kind of regulators came on the 435. The SM2029 shows no specs at all for the 435. The Field Service Bulletin that Duane mentioned may show a better diagram for just the 435 but I don't have that. Contact Duane or see if your JD dealer service manager has something like the SM2029 with 440 diagram or the FSB diagram. If you just need the 440 diagram let me know.
alkay
06-20-2006 14:26:23
 Re: JD 435 Wiring Diagram in reply to Glen in TX, 06-20-2006 13:30:36
Thanks Glen. I'll check and see what I can find out.
Bob in GA
06-20-2006 10:41:59
If one is found, I would also like to have a copy.
Thanks
Bob
