2510 hydraulic problem
Gordie
06-20-2006 08:20:39
Ive just got a 2510 deisel with syncro-range transmission and a 46 loader at aution for 6250.00 dollars. Tractor has fresh engine rebuild with fresh paint and rubber. Very happy with the buy. I have a issue Im trying to sort out with the hydraulics. The front hydraulic pump has a pulsing wine and the hydraulic functions, three point,loader and remotes all work but only when you move the steering wheel to a position that opens power to system being used and then only moves a few inches. The loader works slow and only works while moving steering back and forth as well as all other funtions except for steering and breaks work fine. Loader feed is plumed in behind dash panel on the right side and the return goes to hydraulic filter cap. Acts like pump is starving for fluid. I have changed filter and screen and increased funtion on the selective control valve. This tractor is to replace my Oliver 1800 gas for doing hay. Oliver is for sale if any intrest. Any help on this hydraulic problem is appreciated. Gordie
Gordie
06-21-2006 10:44:22
 Re: 2510 hydraulic problem in reply to Gordie , 06-20-2006 08:20:39
Thanks for the help.I didnt think that looked right. I will hook it up with a tee on the right side in front of break with a quick release and see what happens. Gordie form mid Michigan
matthies
06-20-2006 12:41:27
Disconnect/plug the hoses going to the loader valves and see if that helps any. I'm thinking that the spool valve may be an open center instead of a closed center. If this is the case your pump is constantly pumping/circulating oil through the valve and not going to the steering and other components. chris
Glen in TX
06-20-2006 10:20:39
You said the loader is plumbed under the dash? That probably can't be good. Did they just tie into the remote valves under the dash? There is a better way to plumb it by using a tee in the main supply line on RH side in front of brakes. You can tee into there and use a joy stick valve of the proper type and then run the return back to the filter. If the filter return is not a JD one or one rigged by someone else make sure it isn't shooting oil too hard on the filter destroying filter or you will have stuff plugging the other pump in trans. There is a plug on RH side of syncro-range trans that you can remove to pull out a suction screen for the trans hyd. pump. Clean or replace the suction screen. You'll probably need a new gasket for the plug too. Older screens were metal and can be cleaner while later screens were plastic and should just be replaced. It pumps oil to the main pump up front. If oil is low or screen in there is plugged or you have leaks in line to main pump it will cut down flow or suck air and cause what you describe. If cleaning filters doesn't help check connections and replumb the loader as I think that may be the problem also.
Gordie
06-21-2006 05:05:36
 Re: 2510 hydraulic problem in reply to Glen in TX, 06-20-2006 10:20:39
The loader seems to be connected to the pressure control valve located behind insterment panel on left side.
Glen in TX
06-21-2006 09:43:46
 Re: 2510 hydraulic problem in reply to Gordie, 06-21-2006 05:05:36
Ok, That's what didn't sound right to me before and wondered if it was connected wrong. The pressure control valve is there to equalize hydraulic pressure to insure you always have pressure to the brakes and steering. Nothing in the way of accessories should ever be hooked to it. If it's really hooked to that and not teed in some way to the hyd. selective control remote lines then get it disconnected from there. You can hook it into the remotes on back but if you only have one remote it's better to tee into the line on RH side and use the proper two valve spool control or a new style joy stick control. Hooked to the pressure line on RH side will give you better loader response and then run a return line back to the filter housing. Then it leaves the remote on back free to use for something else also. The 2510 parts catalog also shows some front remote outlets with brackets that were made to be plumbed in the selective control valves for a 2510 for loaders and mid mount mowers and such but finding those might be a challenge too. You can also add quick couplers when plumbing it on RH side with a joy stick valve if loader needs to come off.
Pressure Control Valve third party image
