4020 turbo expert needed!!
Tom Anderson
12-02-1999 08:32:23
My dealer has a 4020, later model console hydraulics before they went to the fender location. Has an aftermarket turobo. They have done an overhaul, and detuned to 120hp. Aftermarket oil pan also to increase capacity and cooling. I need the extra hp, and this sounds like the ticket. Any experience and watchouts I need to be aware of as I look this machine over?
Thanks!!
Gear Head
12-03-1999 19:44:34
 Re: 4020 turbo expert needed!! in reply to Tom Anderson, 12-02-1999 08:32:23
Have a 4020 with M&W turbo kit that is an excellent tractor. It has around 8000 hours on it . We used to pull a 5 bottom 16" plow with it and it would "walk the dog". Ours was Dyno'd and I think it is turning closer to 140 HP. We don't do much heavy work with it anymore but wouldn't be afraid to.
Toivo
12-03-1999 06:14:33
You found a good tractor. The 4020 can handle the turbo and 120 HP with no trouble. The M&W oil pan with a 5 gal capacity is a good add on but also make sure that the fan and shroud have been changed to increase the cooling capacity. You should have a 8 blade fan. An oil filter should also have been added tlo the turbo pressure supply line. I have had 2 & still have 1 4020 set up like this and had no trouble at all.
JDGnut
12-02-1999 13:41:19
Hard to tell you what to look for on a 4020, they are good tractors, but are old. You will like the turbo kit with the extra horses. Like Chad said the tractor will handle the HP as long as you don't get crazy with it. If you are going to lots of very, very heavy pull, might want to look for a 4320. They are about the same HP stock (115hp)and are designed for the extra HP. But I wouldn't be too worried about the extra hp on the tractor, there are lots of tractors around with those kits on them. Well good luck with the 4020.
JDGnut
PS. The console model tractors are the 3020, 4020 build after 1969, with the side consoles, hydraulics on the side.) I ran one of these with the M&W kits for a friend for years. He had the tractor for over 20yrs, best tractor he ever had. (It finally was time last year, sold it for a 4430 w/cab.)
Chad Wink
12-02-1999 11:36:15
I had great luck with my 5010 with the M&W turbo on it, just didn't get stupid with it, and it worked fine.
Chad Wink-Again
12-02-1999 21:34:31
 Re: Re: 4020 turbo expert needed!! in reply to Chad Wink, 12-02-1999 11:36:15
Make sure thst there is still a filter in the oil line for the turbo, and change it every time you change the oil.
