Checking oil on model 50
Rags
06-20-2006 07:34:28
Just checked the oil on my 50 & it seemed awful thin & smelled a lot like gasoline.How could this happen? Thank`s Don. (Just got the tractor).
p55
06-20-2006 11:31:47
 Re: Checking oil on model 50 in reply to Rags, 06-20-2006 07:34:28
Even on the best of gasoline engines, a little speck of dirt can cause major problems. Taking
a minute to shut the valve off at the sediment bowl can save time , engine oil and filter...
and a few hyphonated four letter words...
Learned a long time ago to TAKE the time to shut the gas off. (Learned the hard way, too.)
Hi Frank !
F-I-T
06-20-2006 07:57:20
If your tractor is equipped with an oil-pressure activated fuel shut off diaphragm in the sediment bowl, it could be ruptured, routing fuel up through oil line and into the crankcase. Or the shut-off is leaking, keeping a fuel with a slight pressure (a 12" column or so from the tank) and it is leaking past the float needle and seat in the carburetor, and into the manifold, past an intake valve, into the combustion chamber, past the rings, into the crankcase.
If you have a manual shut-off valve, the float needle or seat is probably leaking, and if it is not real severe, you could just turn the fuel off after each use which should solve the problem, albeit temporarily. You probably still should turn off the fuel after each use AND replace the faulty needle and seat.
Turning off the fuel is good preventative given the high cost of fuel and lubricating oil.
Frank
Rags
06-20-2006 09:13:15
 Re: Checking oil on model 50 in reply to F-I-T, 06-20-2006 07:57:20
Should I change the oil right away?I plan on driving it in a parade in a couple of days. Thank`s Don.
F-I-T
06-20-2006 10:28:10
 Re: Checking oil on model 50 in reply to Rags, 06-20-2006 09:13:15
Absolutely you should change it. Even if it doesn't explode, the fuel will begin to gas off as the oil heats up, make its way up the breather tube and the tractor will run even more rich than it usually does in a parade event.
If you do have a manual shut off, I would be turning it off when not in use.
Frank
Ben.So.Tex.
06-20-2006 09:23:23
Fuel Air Heat, in the crank sounds like a BOOM to me.
Yes you may want to change it, or you might have a real fired up tractor in the parade.
My two pennies..Good luck
Mike M
06-20-2006 08:03:48
I might add the high cost of engine parts too !!
Things like bearings and connecting rods.
Cropman Bob in Central PA
06-20-2006 07:55:29
Gasoline can sometimes leak through the needle valve in the carburetor--especially if the float is defective or not set correctly. Some models (520; maybe 50) had a gasket in or near the sediment bowl that could rupture and allow gas to leak into the oil.
