Grease/Oil leaks @ axle splines
Clemson Tiger
06-20-2006 05:56:55
I have a 46' JD Model A and there's oil leaking around the axle where they come from the gear box. I know the oil is leaking out of the powertrol and into the transmission...is that what is causing the leakage around the axle? Also, does anyone know whats causing the powertrol leakage? is it a difficult fix?
thanks,
CHAD
G/MAN
06-20-2006 07:34:03
 Re: Grease/Oil leaks @ axle splines in reply to Clemson Tiger, 06-20-2006 05:56:55
There are two seals on the axle. One is inboard next to the bull gears, and seals trans/diff lube to keep it in the rear-end. The outer seal is a grease seal, as the outer axle bearing is only lubed by grease, not oil. What's happening is that the inner seal is leaking and is letting oil get out of the rear end. That requires bull gear and axle removal to fix properly. Your Power-Trol is likely leaking at the seal on the PTO shaft where the pump is driven.
Clemson Tiger
06-21-2006 09:00:50
 Re: Grease/Oil leaks @ axle splines in reply to G/MAN, 06-20-2006 07:34:03
Could all of the pressure (gravity) from the oil coming out of the powertrol leaking into the transmission be forcing the oil by the bull gear and out of the grease seal?? therefore, if i fix the powertrol, it might stop? I m not sure if it will have any long term effect but so far its just grease spinning out on the rims while in a high gear. give me a hollar back. appreciate it,
Go Tigers
G/MAN
06-22-2006 07:36:10
 Re: Grease/Oil leaks @ axle splines in reply to Clemson Tiger, 06-21-2006 09:00:50
Highly unlikely, but possible I guess, IF the rear end is getting dramatically overfilled. The seals used are lip-type seals, and if they're in good shape, they should be able to seal well even when completely submerged. The more pressure there is on the garter-spring side of the seal, the BETTER they should seal in fact. There are felt grease seals at the outer axle ends to keep the grease in and the oil out, and those could also be bad, but unless you've recently greased it and gave it quite a bit, it's probably oil forcing the grease out. This really isn't a huge issue unless you're really concerned about some grease and oil leaking out and screwing up a nice paint job or something. If you don't want to mess with it now, just fix the Power-Trol leak and keep an eye on the diff oil level and give the outer bearing a shot of grease now and then. Only thing is that you'll probably end up removing the Power-Trol housing to take care of that, and then you're right there at the bull gears and axles anyway.
