4020 Rear End
mrn
06-19-2006 18:36:23
1968 4020D with hydraulic differential lock won't move unless differntial lock is engaged. When lock is engaged only the left side(looking forward) has power. I'm assuming the rear needs to be rebuilt, but am looking for advice on easy things to check prior to teardown. Also, any advice on rebuild (tips and avoidance items) will be greatly appreciated. Anybody have an idea on what the parts will cost?
This one is going to hurt, isn't it.
mrn
06-20-2006 18:54:01
 Re: 4020 Rear End in reply to mrn, 06-19-2006 18:36:23
Hi All,
Thanks for the tips, I'll probably start tearing it down in a few weeks. I'll try to post some pics.
Thanks again - you don't know how much you guys help.
430WLPG
06-20-2006 18:50:55
My money is on the spiders gears, probably the spider gear shaft is worn off and is letting the spiders just spin. Seen it before, when you lock the diff lock you are locking one spider side gear to the ring gear carrier and that will make it move.
ET
06-20-2006 05:35:18
Pull the right axel off, my bet is that the cast planitary gear carrier in the final drive is broken. It could also be the sun pinon shaft twisted off, either way its in the final drive on the side that doesn't drive. Let us know what you find.
Grumpy
06-20-2006 05:04:40
Check for sheared key or bad hub on axle first. I have seen this on a Case tractor. Stan
JDGnut
06-20-2006 10:26:08
 Re: 4020 Rear End in reply to Grumpy, 06-20-2006 05:04:40
Been there.. Check the key way in the hub first..
Tx Jim
06-20-2006 04:19:27
mrn,I think that one of your pinion shafts in diff. has come loose or broken. You could remove rockshaft housing to see. Tx Jim
Jim in AK
06-19-2006 21:07:36
Big time!
Jim
Chris Kendall
06-19-2006 20:10:51
Does this tractor have powershift or Syncrorange
