720 hard start
pwd
06-19-2006 16:50:33
to buick and blacksmoke's questions on the hard to start 720 diesel---i have checked the inj. timing. starting sequence---start pony (diesel fuel off)compression lever pulled, pull lever to engage big motor,then crack pony wide open, let com. lever off, give diesel motor fuel, it will puff smoke but not start--pull com again to get rpms as high as possible then let off com lever after a couple times of that it will start up. any suggestions? thanks for the help
Blksmok
06-20-2006 06:58:27
 Re: 720 hard start in reply to pwd, 06-19-2006 16:50:33
PWD...does your 720D have the pressure relief device on the top of the injection pump cover that bleeds pressure off the lines back to the tank? If you bleed the fuel lines before you try your starting routine will it start on the first full compression stroke?? As B-D mentioned, check to see if the V mark on the flywheel lines up with the V mark on the end of the crankshaft. If not aligned, your pump timing would be off.
billonthefarm
06-19-2006 21:19:07
Here is something easy and quick to check. Get a hand tach and see how fast the pony is spinning the diesel. As I recall the pony should spin the diesel at about 200 rpm under full compression. It doesnt sound like a big deal but it will make a difference. bill
buickanddeere
06-19-2006 19:21:08
Your starting sequence is good. Perhaps pulling the injector's and giving them a 1/2 turn so they spray away from the tractor is next. Now you can see when they spray and the pattern. Also the piston is accessible to measure true top dead center. The markings on the flywheel may not be accurate, it happens. Sometimes the flywheel gets installed one spline off as well.
