JD 4630 CAN NOT SHUT OFF PTO
Welby
06-19-2006 10:46:08
I have a JD 4630 and the lever that operates the pto moves extremely free and the pto runs continuously. Is it the valve body or something else?
Steve in PA
06-19-2006 13:18:04
 Re: JD 4630 CAN NOT SHUT OFF PTO in reply to Welby, 06-19-2006 10:46:08
Check on the left side of the tractor down in the transmission case there are two aluminum fingers after time they wear and break thats what happened to my 4230. If you look in front of the axle there is a small cover and they're inside there. Not expensive just hard to replace.
Welby
06-19-2006 14:11:21
 Re: JD 4630 CAN NOT SHUT OFF PTO in reply to Steve in PA, 06-19-2006 13:18:04
Thanks. I"ll check it out and let you know if that is the problem.
