4020 vs 4230
rboulware
06-19-2006 06:43:46
Has anyone out there used the 4230? I have seen one this weekend and and it looked like a really nice machine. I have ALWAYS been intrested in the 4020 but would consider a 4230 IF it is as durable as the 4020...does any one know of the "week" spots on a 4230?
thanks..
rboulware
06-20-2006 10:35:07
 Re: 4020 vs 4230 in reply to rboulware, 06-19-2006 06:43:46
Yeah it seems the 4020 has "collecotrs" value inflated in the price of the thing...This is what I want to avoid ..I want to pay for PURE machine..But I want to MAKE SURE I get a machine that is more durable..
David in MD
06-20-2006 06:13:49
I grew up on a 4020 and the first tractor I ever owned myself was a 4230. Considering the work they can do the two are practically identical. I"d prefer the 4230 due to the quad range transmission, the wet clutch, and the heavier fron axle. I will admit that the 4230 is among the worst starting tractors JD ever made. You might find a comparable 4230 cheaper as the 4020 is an antique now.
Chris Kendall
06-19-2006 20:07:47
The 4230 doesn't have as much "lead in its pencil" as the 4020 but if it has cab/air then it has a leg up on the 4020. BUT that is the only advantage over the 4020. The 4230 seems much lighter than the 4020 and doesn't handle pulling as well as the 4020 and the 4020 can handle heavier 3 pt implements much better. I have spent many hours on both of them and like both very much but would take the 4020 over the 4230(unless it had cab/air and I had to bale hay on a windy dry hot day)
MinnieMoFan
06-19-2006 19:36:48
I use a 4230 when i work for my neighbore he does run tractors pretty rough but this is his worst off tractor drinks oil, 3rd rebuild, pto doesnt shut off, and doesnt shift into gears right always jaming into gear and whins when shifting into gear, i dont know about the 4020 but it might be a bit better not sure
Wes Miller
06-19-2006 15:33:46
Our 4230 had 14,000 hr on it before we had to rebuild it. Many of those hrs were hard ones as it used to be our big tractor.
Steve in PA
06-19-2006 08:21:10
REALLY THEY'RE ABOUT THE SAME THE 4020 WAS JUST REBUILT IT HAD 9300 HRS ON IT. THE 4230 HAS ALMOST 8500 AND HASN'T BEEN REBUILT YET IT'S STARTIN TO SMOKE A LITTLE BIT SO ITS COMING DUE FOR A TUNE UP. BUT THE 4020 IS A LOT EASIER ON FUEL TOO.
rboulware
06-19-2006 07:42:31
well...I am asumeing the 4020 is the "tougher" tractor....correct?
Steve in PA
06-19-2006 06:56:27
I have a 4020 and a 4230. Not much difference in horsepower. The 4230 I use to square bale with because of the quad range it gives alot more different ranges of speeds compared to the 4020's 8 gears. But the Quadrange likes to lock in park even on the slightest of hills where the 4020 does not. Also i have had trouble with the pto of the 4230 it has aluminum fingers in the rear end that put the pto in gear and for some reason on mine they bend easy causing the pto to not shut off. also the 4020 is an easier cold weather starting tractor. other than that love the 4230 great tractor but also love the 4020 tough tractor.
Super A
06-19-2006 08:55:10
 Re: 4020 vs 4230 in reply to Steve in PA, 06-19-2006 06:56:27
Regarding the Quad Range locking in park on hills, there should be instructions on how to deal with that down by the shifters. In short, depending on whether or not it's headed uphill or down hill, you put it in gear and barely release the clutch, it will "pop" out of park.
Al
mjbrown
06-19-2006 13:48:42
 Re: 4020 vs 4230 in reply to Super A, 06-19-2006 08:55:10
Yes, it's covered in th owners manual.
