JD 510 round baler
Jack-Ont
06-18-2006 21:21:05
Hello, I just picked up an old JD 510 round baler and I'm starting to regret it already. It picks up the hay ok, but more hay gets bunched up on the wrong side of the belts instead of into the rolling area. I wasted a whole afternoon and can't figure this one out, Can someone tell me whats going on here, or how to correct this?
Hilltopper
06-19-2006 20:09:08
 Re: JD 510 round baler in reply to Jack-Ont, 06-18-2006 21:21:05
I know what you are going through. I have found it works best for me with a 720d tractor to use a wide windrow so you do not have to weave from side to side. The instruction manual calls for a faster gear and running the PTO at slower speed for starting the bale. I usually bale in fourth gear.I do not go full throttle until the bale gets heavy and it is pulling hard.
johns48b
06-19-2006 06:56:29
i had an ih that did the same thing. i had to stop to tie a bale off setting at an angle to the windrow and get some hay all the way across to get the next bale started right or it would push the belts side ways and make a heck of a mess. it takes practice and patience.
Bison
06-19-2006 00:31:44
I have a vermeer 605 D that had the same problem.
I put 10" wide belts on it instead of the 4" and also set the haybine to trow the width of the baler . now I can bale without problems and don't have to weave no more either.
Before I did that the only way to start a bale was to start picking up hay on one side of the baler and steered kwikly to the other side of the swath so as to get a full core across the bale chamber, and even then half the time i was not fast enough to prevent the hay from plipping between the belts. very aggravating to say the least.
These old balers can be finnicky.
Some times it takes a while to get te hang of it.
And mayby your belts are stretched to much.
Take one off and measure it against the original lenght.
Jack-Ont
06-19-2006 03:59:34
 Re: JD 510 round baler in reply to Bison, 06-19-2006 00:31:44
Thanks Bison,
this gives me a starting point, although I don't think it would be possible to put wider belts on as there are guides/seperators welded onto the headframe and tailgate.
