JD 60 Powertrol plug leaks?
hayray
06-18-2006 19:10:59
Every since my wheel rake came un-hitched and pulled the plug out of the power trol housing as the hose and coupling got left behind with it my plug has been leaking on my 60. Nothing is broken but now it leaks if I leave the pump on, also my power trol gradually leaks pressure, nobody at the dealer has been able to answer these questions, any help please?
Ray
retired farmer
06-18-2006 19:32:10
 Re: JD 60 Powertrol plug leaks? in reply to hayray, 06-18-2006 19:10:59
If I remember right, there is an O-ring in the bore where the hyd. fitting goes into the Power-trol. You may have damaged it. It has been about six years since I've seen one but I think I am right. Hope this helps.
55 50
06-18-2006 20:05:39
 Re: JD 60 Powertrol plug leaks? in reply to retired farmer, 06-18-2006 19:32:10
There are two O rings in each hydraulic fitting bore.
hayray
06-19-2006 03:32:59
 Re: JD 60 Powertrol plug leaks? in reply to 55 50, 06-18-2006 20:05:39
Is there a groove that the o-rings fit into? I looked and did not see anywhere where you would think o-rings goto, and then there is a larger entry hole and then another tapered down orifice.
Thanks, Ray
F-I-T
06-19-2006 08:01:22
 Re: JD 60 Powertrol plug leaks? in reply to hayray, 06-19-2006 03:32:59
There are four o-rings, two in the top hole and two in the bottom hole. All are the same part number, A 3190 R. Sometimes they have them in stock, but I think I had to order them the last time. Buy extras so if you drop one you don't have to go looking for it.
It's not an expensive fix, but it is a pain, because you have to work through the small bores. You might be able to gain some access via the side pipe plugs. I like to place a small 6 volt wheat bulb in there as the light helps with depth perception. As for tools, a combination of forceps and bent wires will usually do the trick. Heating a wire tip allows you to burn through the old o-rings so that you can get them out in pieces. This works for me.
It is not difficult or expensive, but it ranks up there on my top ten list of jobs I hate on a cylinder. I think the worst is lower and upper radiator pipe o-ring replacement on a 70D.
Frank
hayray
06-20-2006 05:00:47
 Re: JD 60 Powertrol plug leaks? in reply to F-I-T, 06-19-2006 08:01:22
Thanks Fit,
I will give that a try.
Hayray
