1937 A oil filter part?
jc37A
06-18-2006 18:27:30
There appears to be a part missing between where the filter cartridge meets the spring attached to the bottom of the oil filter(bowl shaped). It looks to me like the spring should be placing tension against something. Thanks for any help!
DSK
06-18-2006 20:37:43
 Re: 1937 A oil filter part? in reply to jc37A, 06-18-2006 18:27:30
Your A was originally equipped with a washable metal oil filter. Apparantly when someone upgraded to the diposable cartridge type they didn't install the AA2095R end plate & spacer which is needed with the paper cartridge but not with the metal cartridge. I've seen this before on a 36 A I bought years ago. This part should be readily available from any salvage yard. It would also be a good idea to do a good housecleaning inside the crankcase as the oil filter hasn't been doing it's job without the plate underneath it.
jc37A
06-19-2006 03:58:19
 Re: 1937 A oil filter part? in reply to DSK, 06-18-2006 20:37:43
I knew something had to be missing! So I need part# AA2095R (plate, oil filter end). Do I also need part# A2444R (snap ring, oil filter end plate retaining)? Thank you for all your help!
