need bigger weights for an 80
80-kid
06-18-2006 12:02:13
well i have a 1956 jd 80 and i have 5 original weights on it.... but were we like to pull it at says that we can only have 4 on the tractor.... is there a jd or anything that weighs more than a 150 lbs. cuz i need the tractor to weigh 10500 or more and now it only weighs 9850 so i need some biger weights... any help alex
Ron Thompson
06-18-2006 12:40:57
 Re: need bigger weights for an 80 in reply to 80-kid, 06-18-2006 12:02:13
Alex, Yes they made larger weights for the 80 JD. The trouble is that you have to take the wheels off to install them. They weigh about 500 lbs each and fit inside the rear wheels. You can also run the JD pancake weights inside of the wheels. Hope this helps, Ron
Glen in TX
06-18-2006 12:22:34
Sounds like a stupid rule to me? There were larger weights used on new generation tractors but some of those might not fit being for 38" wheels. 5010, 5020, & 6030 with 32" wheels used some huge inside one piece weights but those might be more than you are looking for. Other later tractors also used some larger 1 piece inside weights. You might find those as JD weights or as local foundry made back then. Do they allow you to use box car wheels for weights or concrete weights? Those commonly used at one time for weights. Make your own 1 piece weight.
