1944 JD A throtel lever.
ROWDY33
06-18-2006 11:28:43
When you push the throtel lever all the way open it wants to return to the idel position. Anyone have a fix for this trouble?
ROWDY33
06-19-2006 15:31:35
 Re: 1944 JD A throtel lever. in reply to ROWDY33, 06-18-2006 11:28:43
We are tryind a shim in the lever. I believe it will work if the shim wom't wiggle out. Thankyou for the help.
P Browning
06-18-2006 15:50:08
ROWDY33 -- Using suitable leverage, pry the throttle shaft upward (against the spring) just enough to where you can swab the tapered interface with some carb cleaner or bubbing alcohol on a small rag or perhaps even a Q-tip. Get it "squeeky dry" down in there!
I assume you have spring tension holding those two tapered surfaces together -- if not, the tension is needed to provide sufficient friction so as to make the throttle hold where you place it.
I don't know about the dirt thing -- may work. The whole idea is to develop more friction in the tapered interface. Start out with a really good cleaning & ensure its DRY. And if it don't hold, you can always insert dirt! (PatB)
johns48b
06-18-2006 13:57:55
i have a buddy that has a b that did the same thing. he had taken his off and cleaned it up and it wouldn't stay set. an old jd mechanic told him to drop some dirt down in the pivot points and work it in. that cured his problem. there may be some adjustment for that but i don't remember it right now.
