1939 B flywheel question
Ted Dixon
06-17-2006 18:08:29
Does anyone know how tight in foot-lbs that the flywheel bolts should be tightened? SM2004 does not give any reference to this other than they should be tightened "evenly and securely".
I had the flywheel off while I was repairing motor and setting crankshaft endplay.
Ted Dixon
06-18-2006 11:07:22
 Re: 1939 B flywheel question in reply to Ted Dixon, 06-17-2006 18:08:29
Thanks Glen and Pat for the replies. I mentioned the torque wrench because it is possible to tighten it that way if you rotate bolts to a 45 degree angle and remove the oil/crankcase breather stack,also use a short 15/16 socket with a "barrel-type" twist adjustable wrench. I just wanted to use that instead of "mechanic feel" for casting protection. Thanks again.
Glen in TX
06-18-2006 09:55:03
Good and snug is fine when using the appropriate JD flywheel wrench. If don't have a flywheel wrench you can find them from several sellers online reasonably. If the bolts looked stretched or threads are bad turning hard you may want to replace them with some grade 5 or 8 bolts, nuts and lock washers. You can overdo it and crack a good flywheel too by wrenching it down too tight. A cheater pipe on the wrench should not be necessary! As Pat said having the splines clean on crank and in flywheel and the flywheel on the crank properly is important and will insure it tightens good. Flywheel endplay should be .005-.010" without binding. If you get it installed and see the flywheel has moved some reinvestigate as why trying to correct that and tighten them again. Recheck they are tight after it has ran for a while too.
P Browning
06-18-2006 06:40:59
There is no call-out in foot-pounds of torque for those bolts that I have been able to find. One quite safe way, however, is to treat them as Grade 5 bolts & at 5/8-inch diameter, they can be taken to a torque of 154 ft-lbs.
Ordinarily, one cannot get a torque wrench in the right position to perform such an operation. And in that case, you bring them up "evenly & securely" to a reasonable limit on your ability to tighten it. And yes -- I do believe you can over-do it!
Be sure the splines are clean and dry. An oily spined shaft will only make it easier for the flywheel to move. Beyond these notes, this isn't rocket science -- you should be okay. (PatB)
Torque value charts can be found in the new JD-H Restoration Guide -- see the site below.
