HELP !!JD STX 38 MOWER WILL NOT ENGAGE PTO
lapine
06-17-2006 12:00:18
I just had it serviced by the dealer for blade scraping, which they put on a new spindel, I have been thru sheer HE!! with this new dealer. anyway the return it and mower will not engage I pull the PTO and nothing, like something is not hooked up. I printed out some diagrams from the JD site, but could not get a good explanation of which color wire goes to the mower, my grass is 3 feet high now, the dealer took 2 weeks to repair and it don't work, it worked before they took it, it may have scraped but the pto engaged. please help, I only have maybe 1-2 dry days, here in PA it seems to rain every 3 days
Estle Cloud
06-17-2006 18:57:03
 Re: HELP !!JD STX 38 MOWER WILL NOT ENGAGE PTO in reply to lapine, 06-17-2006 12:00:18
I assume you have already looked for loose or broken wiring.
Red wire #200 feeds terminal B on the key switch, yellow wire 400 connects from the key switch to the PTO switch and blue wire #750 connects the PTO switch to the PTO clutch. Black wire #125 grounds the PTO clutch.
A section of the key switch can be defective and everything else will still work and just one section of the PTO switch can be defective. A shorted clutch winding can damage both the key switch and the PTO switch.
Lapine
06-18-2006 12:07:20
 Re: HELP !!JD STX 38 MOWER WILL NOT ENGAGE PTO in reply to Estle Cloud, 06-17-2006 18:57:03
It looks like the blue wire starts the mower as you said, the blue wire has a connector that pushes into the pulley or electrical mower engage, there is a black wire in back of the engine with a plastic connector that goes to nothing, previously I was told that goes to the headlights which I don"t have headlights. last year I had a new wiring put in ,the harness new starter box etc. The only thing I can think of is that they did not connect something, I am afraid to take out the solenoid where the key goes since everything seems to start there, you have to go under the started and remove the bolts holding it, are these just plug in"s or wires that connect or twist together, I have no electrial knowledge, but I will connect the dots if I have to, hopefully the dealer is comming here tommorrow, WHO KNOWS!! They would have had to disconnect the power from the mower to put a new spindle on wouldn"t they?
