JD 435 oil pressure sending unit-What psi?
cdm
06-17-2006 06:23:53
JD 435 oil pressure sending unit at canister. Does anyone know what psi sending unit I should buy? NAPA has several choices.
Thank you in advance,
40joe
06-19-2006 20:32:54
 Re: JD 435 oil pressure sending unit-What psi? in reply to cdm, 06-17-2006 06:23:53
jd part# at11117t not avalable you might call stewart&stevenson @800-460-7711 they carry all the parts for the 2-53 detroit
Henry M
06-18-2006 05:32:52
You may want to price one at Deere. Sometimes their stuff like that is not that expensive on a comparative basis.
cdm
06-18-2006 05:43:42
 Re: JD 435 oil pressure sending unit-What psi? in reply to Henry M, 06-18-2006 05:32:52
Thanks to everyone that is offering advice. I do have the parts manual, and the Deere dealer here says its no longer available, to get it from NAPA. If anyone has that number, I'd really apreciate it.
Thanks again
buickanddeere
06-18-2006 16:59:34
 40psi set point Re: JD 435 oil pressure sending un in reply to cdm, 06-18-2006 05:43:42
The service manual calls for setting the oil pump relief valve at 40psi. So a sender/gauge combination that"s at max indication with 50 psi should be close.
buickanddeere
06-17-2006 06:50:53
1-800-522-7448 for the parts and service manuals you need for this and other service. What ohms rating is the dash indicator? If the pressure switch is origional it's time to toss it and replace too when it's handy to get at.
