620 3 pt problem
jdjack
06-16-2006 19:17:56
I bought this 620 that had been sitting for awhile.
Got it running, noticed that the lift arms go up when you start it. Tried to move level foward will not move, can move it backwards, and lift arms are at the top of travel and they start to bounce alittle. They will not lower when tractor is running, even with putting pressure on them.
Turn tractor off, can move lever full length of travel, and arms will drop. With lever in foward position, start tractor and move lever just alittle back and arms start to go up. Keep moving level backwards arms are at top and start to bounce, and the lever can not be moved passed the halfway point fowards, unless tractor is shut off.
Is there a seal or something leaking? The remotes seem to work good.
Jack
Glen in TX
06-17-2006 09:08:56
 Re: 620 3 pt problem in reply to jdjack, 06-16-2006 19:17:56
Before pulling it all apart you might also first check the throttle valve adjustment that controls the drop speed. It's under a long cap nut on the upper RH side of the control box. Loosen jam nut and turn the screw out to increase drop speed and in to decrease drop speed. Someone could have it screwed in all the way or too far? If that doesn't work or help then you know it's a linkage problem. A I&T JD-16 shop manual or a JD SM2022 service manual for Custom Powr-Trol hydraulics will help. The other hyd. manual for earlier tractors is SM2011.
lonzo
06-17-2006 06:14:42
you have problems with linkage . Remove the battery box and then the cast lid that covers your rockshaft, all the linkage is where you can see it except one valve and that is in front of the rockshaft housing and you must remove the whole back end to get at it. Move the control lever and look for things that don't add up. (rusted pins bent rods and so on ) The rockshaft is down right simple and i guess thats why they don't give much trouble, O one more thing, you may half to cut the bolt head off to get the battery box off, when that happens go ahead and pry the cast cover off and then the cut off bolts can be removed with a pipe wrench. YOU CAN DO IT.
