4020 and clutch feel
Nylon
06-16-2006 11:06:39
Hi Guys,
I know I have asked bout this before. My clutch doesnt seem to slip but it feels like it is at the tail end of grabbing. You can't slip the clutch on it like most clutch powered equipment. It is either there or it isnt. Is there any way to tell if my clutch is on its death bed or not? I would like to not have to tow it out of a bad spot and onto a trialer if I could just drive it on. I probably will have a laundry list of items to fix while it is open.
Thanks,
John
ET
06-17-2006 04:58:18
 Re: 4020 and clutch feel in reply to Nylon, 06-16-2006 11:06:39
The sticker on the tractor about clutch ajustment says MINIMUM of 3/8" freeplay. That is the smallest amount. The service manuel calls for 1 1/2" of freeplay. I always set them between 1 1/2" ans 2" unless they drag. You can keep ajusting until you use all the slot in the clutch pedal. If your tractor has the button clutch in it, it may grab and never relly ease in.
Nylon
06-17-2006 13:43:34
 Re: 4020 and clutch feel in reply to ET, 06-17-2006 04:58:18
Thanks for the info ET & Bob
Bob
06-16-2006 11:56:14
This is a synchro range, right?
Does the pedal have the recommended free-travel before resistance is felt?
Nylon
06-16-2006 20:38:54
 Re: 4020 and clutch feel in reply to Bob, 06-16-2006 11:56:14
Sorry,
yeah it is a synchro. I think it has the free play. I can adjust the pedal so that there is a fair amount more than the 3/8" in free play if you want to have more. I like the clutch pedal snug so I try to keep it close to the 3/8. I just went out and checked and I have about an inch of free play while running but can adjust pedal to have a fair amount more.
Thanks for info,
John
