2640 brakes dragging?
flatbroke farm
06-16-2006 07:03:19
This problem started with heating hydraulics, no leaks at the SCVs or the rockshaft assy, but brake material was found at the filter and sump. When the syptoms began, the trans case was very hot and the brakes failed completely.
My question is could the brakes fail in such a way to cause the heating in the first place? They are the original discs, 30yrs+ Any thoughts would be greatly appreciated.
WTW
06-16-2006 09:28:51
 Re: 2640 brakes dragging? in reply to flatbroke farm, 06-16-2006 07:03:19
Well, Yes In a round about way. The brake valve most likely failed casing brakes to drag causing the oil to warm up/heat and destroy themselves. Check to see if brake pedals are returning to the full up/Off position. If not get corrected or it will do it again. If pedals seem normal jack tractor up apply brakes and check to see if they are releasing if not determine if cause is hydraulic or mechanical by loosening brake line to relieve any pressure they may cause drag. Good Luck, DW
flatbroke farm
06-16-2006 09:37:23
 Re: 2640 brakes dragging? in reply to WTW, 06-16-2006 09:28:51
The pedal function seems normal, but this tractor and many others I have had hundreds if not thousands of hours on always seemed to "chatter" frequently. What do I need to do, replace the discs, possibly machine the pressure plate? This area doesnt seem to be talked about much. Thanks ST
MSM
06-16-2006 09:09:32
Brake failure will definitely cause a multitude of hydraulic problems. Especially if the filter becomes clogged and small pieces and metal grindingd start to be pumped through the system.It will hang up relief valves,cause lift and remote problems,cause scoring on steering valves pto problems etc. If your brakes are bad,park the tractor until repairs can be made. Depending on how long it was run pushing crud through the system,the trans case will have to be flushed,several "cleanup filters"will have to be used and the fluid changed several times,until all the old linings and filings are cleaned out.
flatbroke farm
06-16-2006 09:17:22
 Re: 2640 brakes dragging? in reply to MSM, 06-16-2006 09:09:32
I have heard that brake failure is not very common on these tractors, what would be the cause? Is there something bigger going on?
