4020 not starting
Dale in Ar.
06-15-2006 21:25:25
My son just rebuilt a 4020 diesel for the neighbor and now it will not start.He can get it to start and run on starting fluid but not on diesel.He has talked with a J.D.dealer who told him how to check to see if he may have it 180 out of time.He even took the timing cover off and rechecked the timing marks.All things are looking good.Now,the neighbor had the injector pump rebuilt while the motor was torn down and the injectors are getting fuel at the lines.Now,my question ,is there a way to check to see if the pump was reassembled right or can the pump be a little out of time internally ???Also,can anyone help with ideas that he can look for??? The head was also rebuilt during the rebuild.
Kevin Smolkowski
10-22-2006 21:31:21
 Re: 4020 not starting in reply to Dale in Ar., 06-15-2006 21:25:25
I am havingthe same problem as your son. What did he do to finally resolve the problem?
chucky
06-16-2006 22:33:21
If it is a later model make sure that there is enough power to the electic fuel shut off. I had this happen to mine when I installed a new aftermarket wireing harness and the wire that powered the fuel pump had enough power while the switch was in the on position but did not have enough when in the cranking position. Turns out that the wire that was powering it was hooked in with the accesory and would drop power while cranking and would only start with either like yours. After I wired it to a start wire worked great.
WTW
06-16-2006 08:40:45
Dale, As Bob said, verify that engine is on TDC (On Compression Stroke) and Timing marks are aligned. To verify TDC (compression stroke) you can remove valve cover to see if both valve on #1 cylinder are closed when marks are aligned. Another possibility if you find timing is correct is cam ring in injection pump may have been installed upside-down. When I have seen this happen usually the engine will run just not right. If engine is emitting smoke when cranking and not starting your problem is one of two things, either it is out of time or your compression is to low to create the heat need to fire the fuel charge. I will add a third very unlikely cause as it probably would never happen once in a million times but I seen it happen to a guy once. He had a 4020 in a similar situation to what you are doing , tractor would not start. Did everything under the sun including taking injection pump off a couple of times. You will never guess what was wrong with this tractor, cause this one is for the record book. Tractor also had the starter reworked during this event and in process repair shop decided to save a few bucks and by using reman repair parts. Well it turns out that the "reman / replacement" starter armature was for a IH tractor that caused the starter to turn in the opposite direction!! Kind of hard to start a diesel engine cranking it in the wrong direction. You will say how could you not notice this right away?? Well I can't answer that one but it did happen. I am sure a few guys will get a chuckle out of this one when they read it. Good Luck with your starting problem. DW
Bob
06-15-2006 22:39:28
If the driveshaft has been partially pulled out of the injection pump, it can be put back in 1/2 turn off.
However, if it has been verified that #1 cylinder is at TDC, having completed the compression stroke, and the timing mark is visible in the timing window of the injection pump, that would prove the pump is NOT 180 degrees off.
TimS
06-15-2006 21:59:39
I would look into the injector pump timing...from my 4010 i&t book it looks like the injection pump is driven from the camshaft via the oil pump gear.
It says oil pump is correctly timed if the no 1 piston at TDC on compression stroke, the drive slot is 15 degrees from parallel with crankshaft. V mark on heavy drive lug must be toward engine block.
TimS
06-15-2006 22:08:46
 Re: 4020 not starting in reply to TimS, 06-15-2006 21:59:39
The book also says if you are one tooth off the engine timing will be changed 48 degrees....
msb
06-15-2006 21:57:00
Sounds like it hasn't been bled good.Bleed the fuel filters once more(didn't shut the tank off and forget to turn it back on did he?)Remove the return line on the injection pump and pump the transfer pump lever until fuel comes out.
