4010 Deluxe Seat question..
TimS
06-15-2006 16:21:19
third party image
The 4010 I bought has the spring loaded deluxe seat. The manual says that when you lift the latch and the height adjustment you should be ablt to slide it all the way back and it will stay in that position. The mechanism that holds it here is a coil spring, and it has a wire leader about a foot long, on my tractor that isn't hooked to anything..I figure that should hook onto the base part that the seat part slides on, but I can't figure out where it hooks to, any hints?
Oh, I turned those sway blocks and bolted them back on in the Cat I position, that works nicely. I pulled the transmission cover off ( like I did at the dealership ) to check the transmission out, I ran the tractor and shifted thru all the gears and ranges, the only problem gear is the small gear on the countershaft, it is stripped. I took a couple pictures, I will try and stick them up here.
HTR
06-15-2006 20:52:00
 Re: 4010 Deluxe Seat question.. in reply to TimS, 06-15-2006 16:21:19
The upper end of the seat cable goes on a hook, that is welded, on the bottom side, of AR26632 seat frame.
I guess that you know that the counter shaft is the last piece of the transmission to come out. This is after you split the tractor, remove the rockshaft housing, remove both final drives, remove differential, remove transmission drive shaft, remove differential drive shaft and gears, then the counter shaft. Don't forget to put it back first.
Due to updates of new shaft, you have to replace reverse range gear and first third speed gear. Shaft and the two new gears, $1500.50. You also, may find some bad bearing, shifting forks, synchronizers and who knows what else.
matthies
06-15-2006 20:00:39
Yah the small gear is bad, but the problem is that gear is part of the countershaft and the last shaft to come out of the housing. I'm working on a 4010 right now and found out that when replacing the reverse gear on the topshaft that you also replace the countershaft and the 1-3 gear on the bottom shaft, and more than likely you'll be looking for two gears and a countershaft. Just check the part numbers and find out if they are the updated ones or not. The used countershaft I found cost $250 and the 1-3 gear used was $80, and buying the reverse gear new for $100 I think. Good luck with yours. chris
TimS
06-15-2006 16:25:06
Pay no attention to the green and yellow wires that lead to the headlights in the fenders, I fixed those up with some nice quick disconnect plugs....the headlight switch has a problem, only the outer set of lights come on. I thought about tieing both set of headlights to the low setting until I get that switch fixed, but I didn't want to overload the switch or the relay ( if it has one, I think I saw one in the schematic. )
Glen in TX
06-15-2006 16:50:05
 Re: 4010 Deluxe Seat question.. in reply to TimS, 06-15-2006 16:25:06
That gear doesn't look well on the countershaft. You should be able to view trans parts and the seat parts assembly at JD parts catalog online by clicking on that in left column there.
TimS
06-15-2006 17:00:00
 Re: 4010 Deluxe Seat question.. in reply to Glen in TX, 06-15-2006 16:50:05
I have looked on the jdparts website, I have the parts pages for the transmission printed out.
I couldn't find a diagram for the seat that showed that where that wire leader fastened, and my owners manual and I&T service booklet ( it's to thin to call a manual ) doesn't cover the seat.
matthies
06-15-2006 20:08:56
 Re: 4010 Deluxe Seat question.. in reply to TimS, 06-15-2006 17:00:00
That cable connects to a small bent rod/hook and then adjusted on the side of the seat with a large flat screwdriver. The groove in the slotted head is spring loaded to lock the adjustment in the notches around the slotted head. Confused yet? Once you look you'll figure it out. I fought those cables on alot of tractors until I figured out that adjustment. chris
Glen in TX
06-15-2006 20:54:42
 Re: 4010 Deluxe Seat question.. in reply to matthies, 06-15-2006 20:08:56
Yep, there is a hook on the suspension frame piece for the cable. Just hard to see but suppose it could be broke off too. 2510 service manual I have tells how to service and adjust the seat suspension but the pics trying to show hook and cable are very poor and hard to see.
