JD 1010 firing positions
Tom Naylor
06-15-2006 15:28:10
I am trying to get a JD 1010 tractor running for the local 4h club. The intake and exhaust were switched for some reason and I am guessing the plug wires were switched at the same time, probably by pranksters. All I can find is the firing order. I really need to know which end of the motor # 1 plug is at and which position on the distributor # 1 is at also. It is a 1010 with a 4 cylinder gas engine. Thanks, Tom N
Henry M
06-16-2006 05:31:12
 Re: JD 1010 firing positions in reply to Tom Naylor, 06-15-2006 15:28:10
Tom
No 1 is in the front of the motor.
When you bring no 1 up on tdc on the firing stroke, then look under the dist cap and the no 1 wire will be where the rotor is pointing on the cap.
