In reading past messages, it sounds like JD maybe had 3 locations of the thermostat: 1) In the lower radiator tank to just control the shutters, 2.)In the housing that sits between the Upper water pipe and the block, and 3.)In the housing that sits between the upper water pipe and the radiator. I'm getting ready to redo the entire cooling system, and currently have the shutter thermostat which is leaking, and want to convert to #2 #3. Anyone have an opinion on which is better, more common, or easiest to change out should the new thermostat go bad? What needs to be changed out for each retrofit option? Just the applicable housing? Or does the water pump need to change as well (I think some of the posts said their pumps had some type of a bypass line, which I don't think mine has). Does the lower tank match up between all of the 50's, or do I need to be trying to manufacture a plate to cover the shutter thermostat hole (or is there a better option). Thanks in advance for your time and recommendations.
