JD 510 Baler Lower Belts Flipping and best way to
Tim_in_IA
06-15-2006 06:48:24
I picked up a 510 John Deere baler and it is in good shape except that 2 of the bottom belts are flipped.
Questions:
1. Can they be flipped back without taking the whole lower assembly apart and what is the best way.
2. Can you splice these even though they are endless belts?
3. Why would they have flipped and is there a way to prevent this from happening.
Thanks!
-Tim
John Magness
10-30-2006 08:39:07
 Re: JD 510 Baler Lower Belts Flipping and best way in reply to Tim_in_IA, 06-15-2006 06:48:24
I have used a 510 for 3 years with spliced the bottom belts spliced and let me tell you that this is not the way to go. You can only bale about 20 bales before you have to replace all the splice pins. And it one belt comes apart it will tear up several other belts on its way out. I am in the process of replacing all of the belts not to the continuous kind.
You can find better deals on belts than your JD dealer. I use a company that makes industrial belts for factories in our area
lonzo
06-15-2006 14:47:56
look for a bearing out on the back roller and you won't have much luck trying to make the old belts work.
johns48b
06-15-2006 07:02:25
i have seen the time that i picked up a big stick or limb and it would make a mess of belts. chances are that they are stretched from some accident like that. sorry i can help otherwise.
Tim_in_IA
06-15-2006 10:37:16
 Re: JD 510 Baler Lower Belts Flipping and best way in reply to johns48b, 06-15-2006 07:02:25
Do you know if these would all have to be replaced at once or is it possible to just replace individuals? I would think, unless they are spliceable that they would all need replaced to keep the correct length?
I didn't mention before that I do have a manual, but it doesn't say anything about flipping belts. Since I didn't own it when it happened I am not sure what caused it.
