4230 PTO Lever Disengaging
H2
06-15-2006 04:33:05
The PTO lever disengages occasionally when operating over rough ground. Is there a way to prevent this?
WTW
06-15-2006 07:43:42
 Re: 4230 PTO Lever Disengaging in reply to H2, 06-15-2006 04:33:05
The cab being loose may be some of the problem or not at all. The other factor to include with the cab being loose is if the PTO lever is resting at the end of slot in dash when it is turned on, adjust linkage so lever is just short of resting at end of slot so movement of cab is not working against lever. Another (more common) reason the PTO lever will fall from engaged position is the hydraulic latching system in control valve is not holding the lever on because there is a crack in the PTO control arm. This arm is on the inside / backside of control valve and is made of cast aluminum. It will crack and cause miss-position of valve and latching piston (very common problem on 30 series tractors). Clutch control valve will have to be removed to repair this. To determine if your problem is cab moment / lever interference or internal arm failure, turn PTO on and then turn it off and feel how hard lever pulls to turn it off. If it has a good distinct holding latch feel and you have to pull on lever with light effort to shut it off, it may be cab related. Check lever position in slot and adjust linkage if needed. If it takes very little effort to disengage PTO lever and lever is not resting against end of slot I would bet you have a internal latching problem. Remove clutch control valve to inspect and replace aluminum PTO control arm on backside of valve. Takes me about an hour to do it might take the untrained a couple. Good Luck, DW
MSM
06-15-2006 05:22:41
If the condition only occurs on rough ground,I would look at the cab or platform mounts and bolts. If the bolts are loose or the mounts bad,the cab/platform moving around will disengage the pto.
MSM
06-15-2006 05:21:30
If the condition only ocurs on rough ground,I would look at the cab or platform mounts and bolts. If the bolts are loose or the mounts bad,the cab/platform moving around will disengage the pto.
