820 3cyl diesel hydrolic problem
hawkeyemcp
06-14-2006 16:29:41
I have a 60's or 70's 820 and the lift stopped working. If I crank it, and loosen the high pressure side line coming from the pump, I get no oil squirting out. I am to assume that the pump is not getting oil. What could cause this. (filters, trash, Something lose in the trans case????? ???) Any help or sugestions would be great. If you need any more info please ask.
cannonball
06-15-2006 05:10:06
 Re: 820 3cyl diesel hydrolic problem in reply to hawkeyemcp, 06-14-2006 16:29:41
look for a screen behind a round plug with a 1/2 square hole, you will loose all fluid... i use a tub to catch..you probably have water in fluid and it messes up brakes.. the brake material stops up screen.. be sure to check filter also.. have nice day may god bless
