Using cat I implements on a 4010?
TimS
06-14-2006 12:00:33
I brought my new ( 1961 ) 4010 home last night and I had to remove the sway blocks from the side of the PTO housing to be able to hook up a CAT I rotary cutter I already had. I plan on getting a larger cutter which will most likely be CAT II, but I was wondering how folks stopped sway on this type of 3PH if those sway blocks are off?
I thought about bolting on a couple smaller sway blocks when I need to use CAT I stuff ( post hole digger, sickle mower, etc ).
Any hints?
My owners manual should be waiting at home when I get home from work, I am looking forward to reading through it.
johns48b
06-14-2006 15:07:06
 Re: Using cat I implements on a 4010? in reply to TimS, 06-14-2006 12:00:33
actually it sounds like to me a good excuse to buy another smaller jd and tell ma ma that you have to have it to make the stuff you have work. man i'm glad my wife isn't reading this.
Glen in TX
06-14-2006 13:45:37
 Cat. 1 position in reply to TimS, 06-14-2006 12:00:33
third party image
Sway Blocks interchange for Cat. 1 or 2 positions.
Glen in TX
06-14-2006 13:47:10
 Re: Cat. 2 position in reply to Glen in TX, 06-14-2006 13:45:37
third party image
Sway blocks interchange for Cat. 2 or 1 positions.
Roger in Iowa
06-14-2006 12:11:25
On 20 series you turn the sway block to another surface and bolt it back on. Then it will be for Cat 1.
Roger in Iowa
TimS
06-14-2006 12:58:29
 Re: Using cat I implements on a 4010? in reply to Roger in Iowa, 06-14-2006 12:11:25
Hey, I didn't even think of that! I will look when I get home and see if that works for the 4010 sway blocks.
JDBert
06-14-2006 13:05:43
 Re: Using cat I implements on a 4010? in reply to TimS, 06-14-2006 12:58:29
Yep-it works like the 20's- you lay them flat in stead of the wide way- If I remember right you have to flip them side to side.
