4010 Standard Questions
C Ruda
06-13-2006 09:06:06
I grew up on 4010's and am considering buying one for myself to use while I build my acreage. Until I looked at this one last I night I did not even now a 4010 standard existed. Research on the topic this morning is leaving me with more questions than answers.
What is makes a 4010 standard different?
Are they more or less valuable?
The seller has a 3 point assembly in a pile that came with the tractor when he bought it. Is that easily put on the tractor or is it a major issue?
Thanks
Mike M
06-13-2006 12:03:27
 Re: 4010 Standard Questions in reply to C Ruda, 06-13-2006 09:06:06
I think these are the up and coming collectables as that's what most of those around now grew up on or those that want a tractor the same year they were born etc. At least the 3 pt would make it useful.
Glen in TX
06-13-2006 09:35:31
The standard has fixed front axle, short rear axles and wider rear fenders and could have dust shields. If you aren't wanting to do wide row cropping and it's in good condition buy it along with the 3 point. As far as value it just depends on who else wants to bid more for it. They aren't worth as much in row crop areas but worth more around small urban area farms now or for someone wanting a loader tractor.
C Ruda
06-13-2006 09:48:15
 Re: 4010 Standard Questions in reply to Glen in TX, 06-13-2006 09:35:31
It has loader already mounted and it has been through an engine and clutch overhaul. I would not be doing any crop work at all so that is not an issue. Do you know anything about the difficulty getting the 3 point installed?
Glen in TX
06-13-2006 10:29:57
 Re: 4010 Standard Questions in reply to C Ruda, 06-13-2006 09:48:15
If it's already been doing loader duty check over the front axle, frame, and loader for welds and cracks and loose or missing bolts. Some people can be hard on tractors used for loader duty. You can go view 3 point parts at JD parts catalog located at left column of JD parts site online by entering 4010. Then see if everything you need to mount the 3 point is really there or if something is missing. It shouldn't be that hard to mount it. Make sure the rock shaft is there and works well if you are wanting to use the 3 point later on or that can cost for more repairs later. Check other things and PTO if you want it for bush hogging.
