JD 4010 Steering Out of Place
Norman Al-Anbar
06-12-2006 15:19:28
On a average tractor when you turn the steering wheel from right to left you get 5 full turns. When I start my tractor the wheel stay on the center when I try to turn to the right the wheel is lucked, when I make two full turns the wheel and tires turn to the left and then stop., however I get three more turns without the tires getting moved. When I turn back the wheel to the right I get three empty turns and then the tires move on the fourth turn and stop dead center. It is like the steering wheel moved three turns to the left.
I left the tractor running for long time and kept the steering to the right hopping it will adjust itself but no luck, I had problem with the hydraulics but I changed all the oil (11 gallons) and the filters. Any ideas?
msb
06-12-2006 20:32:15
 Re: JD 4010 Steering Out of Place in reply to Norman Al-Anbar, 06-12-2006 15:19:28
Sounds like you have lost the cotter pin that holds the valve operating spool in proper position.Never heard of it happening,but stranger things have happened.Remove the steering valve and have it rebuilt by someone who is trained to rebuild them.Its not a job for amaturers.It takes special set up and adjustment tools also.
Norman Al-Anbar
06-13-2006 06:57:40
 Re: JD 4010 Steering Out of Place in reply to msb, 06-12-2006 20:32:15
I followed the instruction in the service manual to take this out, however I did see the cotton pin in place that one attached to the control valve adopter, is this is the one that you think came out? Do I still take the steering valve and send it for repairs?
Also how can the hydraulic oil keep changing to look like is mixed with water, is there is a way that water comes in contact with the hydraulic oil? I am not loosing water in the radiator�I changed the oil, flushed the system and changed the filters but the oil changed again and still has no pressure to lift the PTO but I do have the power brakes on and working. It took about little more than 11 gallons and I did use the recommended one I believe was 303...something...God bless you for your help and thank you .I am sorry but we live in rural aria and no one will come and fix the tractor or take it for repair that far�and I had no problems with the tractors until I left and came back after few months
donmyeil
06-12-2006 16:56:40
The seals in the steering motor are worn out. Hold the wheel to full right and the steering will resyncronise. To prove this there is a small hose on the top of the oil cooler you can remove ,(plug the oil cooler with a k-plug) and turn the steering wheel .shouldnt be hardly any thing come out of the hose.
Norman Al-Anbar
06-12-2006 17:56:11
 Re: JD 4010 Steering Out of Place in reply to donmyeil, 06-12-2006 16:56:40
Thank you for your speedy reply...I did that and I kept it turned to the right for about 20 min but no changes and also I am still having problems with the hydraulic oil, I changed the oil as it was turning milky as it has water and put 11 new gallons of hydraulic oil and changed the oil, but today I can see the oil changing again after running the engine for � hour.
mike w J
06-14-2006 13:42:10
 Re: JD 4010 Steering Out of Place in reply to Norman Al-Anbar, 06-12-2006 17:56:11
Is it water in the oil or is it getting foamy from air being sucked threw the pump is it milky colored before it runs or only after?
Norman Al-Anbar
06-14-2006 14:57:02
 Re: JD 4010 Steering Out of Place in reply to mike w J, 06-14-2006 13:42:10
First time I changed the oil I got about 1/2 gal. water before the oil start coming milky, but now after I changed the oil and filter it gets milky after I keep the tractor running for over 1/2 hour but it go back normal again when it is cold...now I do not have pressure to left the PTO but I have breaks ok, the steering is three turns off base to the lest, when I start the tractor the steering go straight but the wheel is far right when I keep it to the right to adjust itself nothing happen but when I turn to the lest the tires go left and stop after the second turn. After that I have three more turns to the left but blanks nothing is moving but the steering wheel ad when I reverse the process. I get only normal sound when I turn the steering
Mike w J
06-14-2006 19:42:34
 Re: JD 4010 Steering Out of Place in reply to Norman Al-Anbar, 06-14-2006 14:57:02
If there was that much water in it then it would not all come out on the first or maybe the 2nd drain it could be condenced on everything inside and in the pumps also in the oil cooling radiator any place that gets oil from the transmission .I would take the plug loose in the trans. housing just enough to let the water drip out it will come out before the oil it will take a while and you will have to do it more than once has it rained a lot there if the 4 bolts that hold the platform down are gone some water could get in there. The steering might be air in the system if the 3point don't lift you must have an internal leak or a valve stuck open does the oil ever get hot? it could be the steering seals in the frontend But if the 3point hitch does not lift That needs to fixed first .
Norman Al-Anbar
06-14-2006 19:54:27
 Re: JD 4010 Steering Out of Place in reply to Mike w J, 06-14-2006 19:42:34
Thank you for the reply...I will do that in the morning...The oil does not get hot and I do not see any leaking from any where outside...I will look at the service manual and follow your instructions first and then see what next...God bless you...You are correct the floor cover was open and we had snow and lots or rain...
