umbrella
70D
06-12-2006 13:33:28
I just put a new umbrella on the old 70D and it just does"nt look right I used a JD bracket that bolts to the back of the seat and then a new umbrlla from JD I was wondering how high I sould have the umbrella from the seat maybe I have Mind to high any replys are welcome
RICHARDJ
06-12-2006 14:20:02
 Re: umbrella in reply to 70D, 06-12-2006 13:33:28
On the top of the right rear axle you should find 2 (depending on year) threaded holes. Weld a horizontal piece of metal with holes drilled to fit the holes on the rear axel to a vertical pipe that is large enough for the "brella" pipe to fit into. Bolt the pipe to the rear axle. Drill a hole at the top of the vertical pipe and weld a nut to the outside of the vertical pipe. Bend a bolt that will fit this nut to make an "l" handle.
Insert the "brella" into the upright pipe, adjust the height (you can actually get it high enough to stand under) and tighten down your "locking handle". The "angle adjuster on the breller" works, you can swing the "brella" wherever you want it. Works great to move the thing to keep up with the sun.
