4010 hydraulics stopped working
Derek Edwards
06-12-2006 06:06:08
I was using my 4010 when suddenly there was a loud shrieking noise from the front of the tractor. I turned it off, When I started it again the shriek was gone but a clattering noise was coming from the area near the hydraulic pump. None of the hydraulic things work - steering, FEL, etc. What is likely to have happened? What should I do?
Thanks
Derek
JD @ Antique Acres
06-12-2006 08:53:50
 Re: 4010 hydraulics stopped working in reply to Derek Edwards, 06-12-2006 06:06:08
My guess is that the splines tore up in the coupling. I had that happen once, it comes from the coupler being loose and over time it eats the splines up.
ET
06-12-2006 06:33:29
The sound you heard was most likly the metal flex plates tearing apart in the hyd. pump drive coupler. They are easy to replace.
gwece
06-12-2006 06:26:50
Check the coupler that drives the hydraulic pump. It may have become loose to cause the chatter. I had one come apart and go into the radiator once.
Derek Edwards
06-12-2006 10:33:15
 Re: 4010 hydraulics stopped working in reply to gwece, 06-12-2006 06:26:50
Thanks for the imput everyone. Will it involve much dismantling to check out the plates/splines etc? What is the order of taking it apart to find out?
Thanks
Derek
JD @ Antique Acres
06-12-2006 11:33:51
 Re: 4010 hydraulics stopped working in reply to Derek Edwards, 06-12-2006 10:33:15
Take the coupler apart that connects the pump drive and the crankshaft drive. Now first check for wear on the coupler itself and the neoprene bushings. If this checks out now check the pump drive. There should be enough clearance to slide it off. You said you had no hydraulics either the splines are worn off so the pump doesn't turn or it may now be in the pump itself. Follow these steps to narrow it down.
Derek Edwards
06-13-2006 06:00:53
 Re: 4010 hydraulics stopped working in reply to JD @ Antique Acres, 06-12-2006 11:33:51
Thank you for your advice about taking the coupler apart. I found that the female splines are completely worn off the connector, but the shaft splines are in good condition.
I appreciate your help a lot. This is the second time I have sought advice on the forum and both times the advice was clear and accurate.
Many thanks.
Derek
JD @ Antique Acres
06-13-2006 07:06:27
 Re: 4010 hydraulics stopped working in reply to Derek Edwards, 06-13-2006 06:00:53
Those pump drives are pricey. Make sure that the coupler is in good condition, not worn and that those neoprene bushings are good. If they are worn it will cause a vibration which could also ruin those splines on the drive.
Derek Edwards
06-13-2006 20:35:42
 Re: 4010 hydraulics stopped working in reply to JD @ Antique Acres, 06-13-2006 07:06:27
Thanks Joel. Those drives ARE indeed pricey! The local JD dealer wants Can$230 for it! I don't know if there are jobber ones available but unfortunately I can't afford to wait.
Regards
Derek
