JD 4010 temp?
123 Farmer
06-11-2006 19:28:40
How hot should a 1961 JD 4010 run. (engine temp) I just bought a 4010 and the temp guage was broken so i replaced it with one whtih numbers and reads around 210-220 when working hard. Is this too hot or ok. thanks.
msb
06-11-2006 20:36:20
 Re: JD 4010 temp? in reply to 123 Farmer, 06-11-2006 19:28:40
Thats pretty warm.Try putting a thermometer in the coolant when it reads that hot to check the accuracy of the gauge.The sending unit is located in the hottest part of the head on those tractors.It was partially corrected on the 20 series by adding a couple of bypass hoses to the front and rear of the head.
